40 Versions of the Same Image — Image Clean Up
  • Hi team,
    My host is just moving my site to a dedicated server but has queried why every image creates 40 versions? The uploads folder is 15GB as a result, which is insane as the images are all websafe/small file sizes.
    Could you shed any light on why this would be?
    14M ./generatepress
    9.5K ./wp-post-to-pdf-enhanced-cache
    1.1M ./useanyfont
    512B ./et_temp
    30M ./2012
    1.2G ./2018
    688M ./2020
    26K ./db-backup
    2.6G ./2015
    512B ./instant-ide-manager
    3.5K ./ShortpixelBackups
    268M ./2023
    168M ./2024
    2.3G ./2016
    5.0K ./abd_libs_dynamic_css
    1.5K ./woocommerce_uploads
    641M ./2014
    2.0K ./tcb_content_templates
    1.8G ./2019
    227M ./2013
    268M ./2021
    66K ./generateblocks
    132K ./wp-staging
    604K ./wc-logs
    2.0K ./wpseo-redirects
    1.0K ./backup
    39K ./uag-plugin
    115K ./spai
    420K ./tve_leads_templates
    1.5K ./broken-link-checker
    4.2G ./2017
    85M ./2022
    6.0K ./mailchimp-for-wp
    15G .
    Is there any way of safely locating and removing unused images?
    Best
    Caro
  • Hi Caro,
    Is the generatepress folder in the wp-content folder?
    If so, it should only have things like a couple of stylesheets and local fonts (if you’ve used that feature). It shouldn’t have any images at all.
    What kind of images are you seeing in there?
  • Hi Tom
    Yes — GP folder is in themes folder in wp-content.
    It contains two folders: assets and inc — each containing various folders and files. But there are lots of loose .PHP, .CSS files in the main folder also. Have taken a screengrab for you to see.
    https://www.awesomescreenshot.com/image/50450072?key=17385cae1bd40cbb6496272edaa7f1c1
    I think my host was querying the uploads folder. I went into the back end yesterday and there were 182 version of just one image alone!
    https://www.awesomescreenshot.com/image/50450056?key=52169d5805290e7089708d66aa924cc5
    We wondered if there was a safe way of removing the copies of the images that weren’t in use.
    I replied to this post on the forum — someone else was having a similar issue: https://generate.support/topic/unused-images-recommend-a-tool-or-plugin/
  • It contains two folders: assets and inc — each containing various folders and files. But there are lots of loose .PHP, .CSS files in the main folder also. Have taken a screengrab for you to see.
    This is correct. However, there should not have any images.
    Can you show us the folder path? it’s been cut off in your screenshot.
