500 Internal Server Error When Saving Elements “nonce” error + post.php Fails
  • Hello team,
    I am facing a problem while editing or saving Elements like Hooks and Blocks in GeneratePress Premium.
    Whenever I click on update or publish, the request to /wp-admin/post.php fails with a 500 Internal Server Error. In the browser console, I also see this error:
    {“result”:false,”error”:”nonce”}
    This issue happens only with GeneratePress Elements. Normal posts and pages are working fine.
    I have already tried the following:
    Disabled WP Rocket plugin
    Disabled Redis caching from wp-config
    Increased memory and execution time in wp-config
    Enabled debugging, but nothing useful is shown in debug.log
    Used the Health Check plugin and activated only GeneratePress and its premium plugin
    Cleared Varnish and browser cache
    Re-uploaded wp-admin and wp-includes folders from fresh WordPress download
    Still, the issue is not solved. I checked the Network tab and the post.php request returns a 500 error without any response body.
    Can you please check if there is any known problem related to nonce validation or saving Elements in the latest version?
  • https://ibb.co/Hf9pwRkB
    Here is the screenshot attached
    We haven’t received similar reports from other users, so this is likely a unique issue on your site.
    If you go to Tools > Site Health, are there any issues highlighted there that might be related to the problem and need addressing?
  • Hello
    There is no such major issue in the Tool > Site Health
  • Is it a live site? if so, can you prepare a staging site and provide the admin login so we can see the issue in the backend and do some debugging?
Viewing 5 posts - 1 through 5 (of 5 total)
