Karissa
This is how the footer should look
but on the website it looks like this
https://www.cplchado.org/vendor-application/ -
Hi Karissa,
To test, can you try a) and if that doesn’t work b) here:
a) Choose Inline Embedding for the CSS Print Method in Settings > GenerateBlocks.
b) Regenerate your CSS files in Settings > GenerateBlocks. -
Karissa
Thank you! I gave both of those options a try with no success 🙁
edit the footer, select the Container Block that has the “bad” styled content, in the block toolbar 3 dot menu select Duplicate, and then delete the original. Publish the changes after that.
This should regenerated the CSS classes and fix the issue. Let me know.
Karissa
Thank you both, this resolved the issue!
Glad to be of help!
