A Snippet is required to update the POST META FIELD from PODS custom fields
  • I’m trying to retrieve the custom fields created by PODS on custom post types via the dynamic data feauture of Generateblocks PRO. I can’t.
    I guess I need a script to automatically write PODS’ custom fields to the regular WP meta fields. I can’t display the fields even though I write them manually on dynamic data POST META FIELD. The only way I can make them display on the front end is using PODS shortcode and their magic tags with respective fields.
    Is there such a plugin or script that makes the custom fields on PODS created custom posts to be retrieved by generateblocks?
    PODs writes its data to Post Meta, see my reply here:
    https://generate.support/topic/pods-dont-display-the-post-title-instead-displays-the-post-id-only/#post-99719
    Lets get that resolved and revisit this IF its required.
