fgonzaleznavarro
I need to add a label to the search form modal, so its compliant with accessibility rules
this is the code that currently the theme spits out which has a label but its not linked to the seachfield:
<div class=”gp-modal gp-search-modal gp-modal–open” id=”gp-search”>
<div class=”gp-modal__overlay” tabindex=”-1″ data-gpmodal-close=””>
<div class=”gp-modal__container”>
<form role=”search” method=”get” class=”search-modal-form” action=”https://perkinsglobalcommunity.org/lac/staging/4478/”>
<label class=”screen-reader-text”>Buscar:</label>
<div class=”search-modal-fields”>
<input type=”search” class=”search-field” placeholder=”Buscar…” value=”” name=”s”>
<button aria-label=”Buscar”><span class=”gp-icon icon-search”><svg viewBox=”0 0 512 512″ aria-hidden=”true” xmlns=”http://www.w3.org/2000/svg” width=”1em” height=”1em”><path fill-rule=”evenodd” clip-rule=”evenodd” d=”M208 48c-88.366 0-160 71.634-160 160s71.634 160 160 160 160-71.634 160-160S296.366 48 208 48zM0 208C0 93.125 93.125 0 208 0s208 93.125 208 208c0 48.741-16.765 93.566-44.843 129.024l133.826 134.018c9.366 9.379 9.355 24.575-.025 33.941-9.379 9.366-24.575 9.355-33.941-.025L337.238 370.987C301.747 399.167 256.839 416 208 416 93.125 416 0 322.875 0 208z”></path></svg></span></button>
</div>
</form>
</div>
</div>
</div> -
Do you want to add
aria-label
to the search field? if so, try this PHP code, I’ve added this line:
aria-label="search-fields"
, so locate this line and change it to whatever you want to use for thearia-label
.add_action ('wp', function() { remove_action( 'generate_inside_search_modal', 'generate_do_search_fields' ); }); add_action( 'generate_inside_search_modal', 'generate_custom_do_search_fields' ); function generate_custom_do_search_fields() { ?> <form role="search" method="get" class="search-modal-form" action="<?php echo esc_url( home_url( '/' ) ); ?>"> <label class="screen-reader-text"><?php echo apply_filters( 'generate_search_label', _x( 'Search for:', 'label', 'generatepress' ) ); // phpcs:ignore WordPress.Security.EscapeOutput.OutputNotEscaped ?></label> <div class="search-modal-fields" aria-label="search-fields"> <input type="search" class="search-field" placeholder="<?php echo esc_attr( apply_filters( 'generate_search_placeholder', _x( 'Search …', 'placeholder', 'generatepress' ) ) ); ?>" value="<?php echo get_search_query(); ?>" name="s" /> <button aria-label="<?php echo esc_attr( apply_filters( 'generate_search_button', _x( 'Search', 'submit button', 'generatepress' ) ) ); ?>"><?php echo generate_get_svg_icon( 'search' ); // phpcs:ignore -- Escaped in function. ?></button> </div> <?php do_action( 'generate_inside_search_modal_form' ); ?> </form> <?php }
fgonzaleznavarro
That worked, thank you.
jmurphree
I think this is what I’m looking for today, but can this code be included in Elements to keep everything simple and from having to edit the Functions theme file?
To be clear, this will add a label to the search modal on the menu bar without affecting the functionality of the modal when activated?
You can use one of the methods to add this code:
Adding PHP: https://docs.generatepress.com/article/adding-php/It can NOT be added to an element.
Correct. But please note, it only modifies the default GP search modal, if you are using a custom one, it will not work.
jmurphree
Yeah, I am looking to add the label to our custom modal.
jmurphree
This is what we want:
If you are saying adding a
<label>
to the form html or adding thearia-label
attribute to the form, we can not help with that, you would need to reach out to the custom form provider.If you mean to add
search
text in front of the search icon, we can help!But can you open a new topic and link us to your site?
jmurphree
Ahh, it’s actually the latter. My bad, will do – thanks!
No problem 🙂
