Accordion
  • https://ettiennevorster.co.za/service-providers/
    I have set the first four items so that they open by default.
    It works. But do not close when I click on the arrow at right top corner.
    The rest of the items I have set not to open by default.
    But they do not open when I click on the right top corner arrow.
    What do I do wrong?
    Please help me.
    Ettienne
    You are using the v1 accordion block, can you swtich to the v2 block at generateblocks > settings?
    Then re-add a new accordion block, it will be v2, you should be able to replicate the same effect without having issues.
    Let me know if this helps!
  • Hi Ying,
    I went to the dashboard > generateblocks > settings.
    And switched off the toggle for v1 blocks.
    The issues persist.
    Please help me.
    Ettienne
  • Did you add a new accordion block?
    The existing blocks will remain as v1. Can you try adding a new accordion block to see if the issue persists for the v2 accordion?
  • Hi Ying,
    I added a container and a new accordion block inside the container.
    The issue persists for the v2 accordion.
    Regards
    Ettienne
  • Can you provide an admin login for me to check the v2 accordion?
    Please edit your first post on this topic, and add the site credentials in the private info field. It will only be seen by the support team.
