Accordion default open items
    I love the new tabs and accordion in Generate press. I have one question. I want all items of the accordion open on desktop (using default settings) and closed on mobile. Is this possible? The current default setting is for all screen sizes.
    Regards,
    Martijn
    thanks for the kind words 🙂
    Can i see what you have so far on your site ? It may be possible with a little extra JS.
  • Hi David, great. I’ve added login details for the website (that’s work in progress) below.
    Regards,
    Martijn
  • You could try some JS to “click” on each accordion item after to load to open them all and only on larger screens:
    <script>
    const accordionItems = document.querySelectorAll('.gb-accordion__item');
    if (window.innerWidth >= 768) {
      accordionItems.forEach((item) => {
        const clickEvent = new MouseEvent('click', {
          view: window,
          bubbles: true,
          cancelable: true
        // Dispatch the click event on the accordion item element
        item.dispatchEvent(clickEvent);
    </script>
  • Hi David,
    Thanks. But I can’t get it to work properly. I’ve added the script to the page (template).
    My accordion items are currently open by default on the desktop and I hide the accordion title on desktop.
    Am I missing something?
    Kind regards,
    Martijn
  • Ooh.. I didn’t realise the entire page were accordions.
    Ok, remove the script I provided.
    Then set all the items to be closed by default.
    We can then use some CSS on desktop only to force them ALL to be open.
  • Hi David.
    No problem. Could you give me a hint on how to open them by CSS?
    Regards,
    Martijn
  • Something like this:
    @media(min-width: 769px) {
        .open-on-desktop  .gb-accordion__content {
            max-height: inherit !important;
    And select the Accordion Items Block and give it a class of: open-on-desktop
    If that don’t work, then close the accordions on desktop and let me know
  • Hi David.
    Thank you very much.
    All accordion items block settings disabled -item default open- and are now opened on desktop by default and closed on mobile, as intended. It works perfectly.
    Excellent support, as always. I learned a lot. I did not know that opening and closing the accordion items could be solved even with CSS instead of javascript.
    Sincerely,
    Martijn
  • Awesome
    Glad to be of help 🙂
