mariotoleonardo2
I would like to know if it is possible to split the “Accordion” into two columns.
In fact, I managed to do it, but the right side is not synchronized with the left when opening and closing a FAQ.
That is, when I open a question, the top or bottom one automatically closes, but if one of the side is open, it continues.
Here’s an image of how I structured it: http://tee.leonardomarioto.com/wp-content/uploads/2023/04/acc.jpg
mariotoleonardo2
Detail: I realized that it is also losing some settings, such as Transition Fade.
Hi Mario,
For reference, can you share the link to where you have this constructed?
mariotoleonardo2
You don’t need to use a Grid block inside the accordion, the accordion container can be set to
display:flex
andwrap
, then you can set all the accordion item blocks to50%
width.Here’s a screenshot for your reference:
https://www.screencast.com/t/qyymTk7ssXXh -
mariotoleonardo2
Can you set the width of the Accordion Items first to 50%? See: https://share.getcloudapp.com/Kou96KwW
mariotoleonardo2
I had also placed a setting of 2% that I saw in the previous image. With her it didn’t work, but without, yes! LOL
Thank you, very much!
You’re welcome, Mariotoleonardo!
