draguignan
I’m trying to reproduce this page https://www.ville-draguignan.fr/la-ville/conseil-municipal/arretes-decisions-et-deliberations/ on this new website : https://actes.ville-draguignan.fr/
But the accordion structure is different and I don’t understand that happen?
Look my screenshot : https://postimg.cc/gallery/WqLhKSmBest regards
Willy -
The 2 sites, one is using v1 blocks and the other one is using v2 blocks, the UI is different which is expceted.
you can check if you are using v1 at generateblocks > settings.
draguignan
Ok where I can check it in setting exactly?
If I updated the plugin on http://www.ville-draguignan.fr website, the v2 is selected automatically? And I should change the css for accordion? Or the v2 select is an option?
Best regards -
If your site already has GB installed and you were using v1 blocks, updating GB plugin will NOT switch to v2, unless you manually change it at generateblocks > settings.
And your existing v1 block will NOT automatically convert to v2.
If you want, you can manually convert some of the v1 blocks to v2 by following this guide: https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/
On a new site, the blocks will be v2 by default.
I’m not sure what you mean by “And I should change the css for accordion? “, do you have custom CSS for v1 blocks?
draguignan
Hi, ok I understood thanks.
Yes I customized css for accordion.
Regards -
Ok, let me know what your CSS is, so I can help adapt it to fit v2 structure 🙂
draguignan
It’s ok, I reintegrate it. Thanks
Glad to hear that 🙂
