owlsliveintrees
Hi ya’ll,
I’m trying to get GB Pro Loop to show my display value on my ACF date picker field.
Does it only show the return value? That would be tough because:
I want to show the date as F j
But i also need to order and filter by year.
But if GB Pro only allows me to display the return value, I’m kind of stuck.
GB Pro should keep the return format you set in the ACF date field when you pull it via a text block.
This will require custom coding. Let me know some more details, so I can write the code for you.
owlsliveintrees
Hi Ying,
Nah, I can handle that part… I think. But being able to choose between the return value and display value in GB would be cool in the future.
OK, let me know if you need help.
