ACF Field for Blogpost Intro Text
    I would like to use ACF to write dynamic blog post intro texts.
    I created a field group and tried to select it under dynamic content, but the field group doesn’t appear to get selected.
    Can you help on how to make use of ACF?
    I added a screenshot of what text I would like to write via ACF fields.
    Thank you!
    You need to set REST API to TRUE for each of the fields so that GB can access them.
  • Hi Ying!
    How do I do that? What is Rest API?
    How can I then define a text that should be written via an ACF field?
    Thanks a lot in advance!
  • Thanks Ying,
    thanks a lot for your help!
    How do I have to fill out the fields in the ACF settings?
    I added 2 screenshots to the private info box.
    And what would be the next step?
    How can I assign ACF fields to particular blocks in GeneratePress?
    Thanks in advance!
    Looking at the screenshot, the REST API for that field is already active.
    Are you working on this in a Block Element or in a regular post or page?
  • Hi Alvind,
    yes, but without filling out the fields, I cannot save the settings.
    What should I enter in the URL field?
    I am creating a Blog Post hero as an Element.
    Thanks in advance for your help.
  • What should I enter in the URL field?
    What URL field are you referring to? I don’t quite understand your question.
