ACF Gallery image size
    How can I control the image size of images retrieved from an ACF gallery?
    AFC Gallery image settings
    It should work the same way as setting a size for a regular Image block.
    Can you share what issue you’re running into?
  • Well, the Image Block has an option for image size:
    Featured Image
    It’s not the case with Loop Item:
    Loop Item
    And in both cases, the Size setting in the Settings panel is disabled:
    Size
  • Ah, got it.
    For an ACF Gallery field, {{loop_item key:ID}} will always return the full-size image.
    If you want a specific size, use the sizes key instead:
    Medium: {{loop_item key:sizes.medium}}
    Thumbnail: {{loop_item key:sizes.thumbnail}}
  • Thanks.
  • You’re welcome
