anthvale
I have some Dynamic Headlines and Images inside a page hero and the text is working but the images aren’t showing and I can’t seem to figure out why.
As you can see at the URL I provided, the title and two custom fields are showing but there should be a grid of 8 images below the text and for some reason they won’t show.
GB’s dynamic feature is not compatible with the return value set to
array
at this moment, unfortunately. -
anthvale
Interesting. Like, at all or in certain scenarios? I have another website with the same exact setup and it’s working perfectly. Like this page I attached.
Hi Anthvale,
Currently, the Dynamic option isn’t able to retrieve any form of array unless you specifically set it to grab “List of terms”.
How are you setting up this Array on the page where it is working?
anthvale
I’m really not sure and I’m quite unfamiliar with all these terms. But, these are the screenshots of the settings I’m using if that helps:
https://snipboard.io/2ASZkD.jpg
https://snipboard.io/qN1JA8.jpgDoes that help?
in your ACF Field, the Return Format for images needs to be either Image URL or Image ID. It won’t work with Image Array
anthvale
Ok, it is working set as Image Array on the URL I’ve attached here. Should I change it? I’ll try Image URL on the website I originally contacted about.
Thanks, Dave
Hold up – i may have misread – what site is it working on ?
anthvale
On this site here it’s working. These two pages for example:
https://www.patriottractor.com/showroom/tractors/yanmar/yt347c/
https://www.patriottractor.com/showroom/attachments/bad-boy/grapples/On the website I originally contacted about, it is now working when I set ACF to Image URL.
But, it is working on patriottractor.com when set as Image Array
How odd, the Array option is meant to support multiple images, which GBs current dynamic data won’t handle which is why i said to avoid. The fact its working elsewhere means i have to do some more homework lol
Are you ok with using the URL on the current site?
anthvale
Absolutely, it’s working great. I guess my only question is should I go back and change all the one’s set to Array on the other website? Will that break at some point? I guess it’s only 4 or so inside ACF so I may as well?
Thank you, Dave
If it works then probably best to not touch it lol
Glad to be of help
