Is there any support for ACF Relationship fields in GB? Specifically:
1. I have a relationship field on Posts which creates a relationship with posts in a ‘members’ CPT. I want to set up a reverse query using the Query Loop Block (used on the ‘single’ Members CPT template) to retrieve blog Posts for which the current Members CPT post is set as a relationship. Along the lines of:
$current_member_organisation_id = get_the_ID(); $args = array( 'post_type' => 'post', 'meta_query' => array( array( 'key' => 'member', // The ACF relationship field key 'value' => '"' . $current_member_organisation_id . '"', 'compare' => 'LIKE' ) ) );
2. Elsewhere, I’d like to pull in the currently post’s relationship fields via Dynamic Data on the Headline block.
theres no direct integration as yet.
But you can write custom queries for a the Query Loop block.
See here for a similar example:https://generate.support/topic/how-to-create-a-query-loop-for-custom-pages/#post-108624
David, you are, as ever, a flipping legend!
For anyone else finding this post, this is my filter for this use case:
//Custom query for GB Loop Block: add_filter( 'generateblocks_query_loop_args', function ($query_args, $attributes) { if ( ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'member-related-posts' ) !== false && ! is_admin() ) { // get the related post ID $current_member_organisation_id = get_the_ID(); // Merge the current $query_args with the new args return array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'member', // The ACF relationship field key 'value' => '"' . $current_member_organisation_id . '"', // The current member organisation ID wrapped in quotes 'compare' => 'LIKE' ) ) ) ); } return $query_args; }, 10, 2 );
Awesome – glad to be of help.
I just spotted question 2 – do you need assist with that ? -
If you have a solution for 2, that would be awesome… I’ve tried referring to the meta key but that doesn’t seem to work.
Option A – Query loop
if all the related field data was grouped together then you could use a Query Loop block to return all the necessary fields in one go using the same method as aboveOption B – Shortcode.
You could build a custom shortcode that allows you to specify the Relationship field and the Field value you want to returneg.
function acf_relationship_shortcode($atts) { $atts = shortcode_atts( array( 'field_name' => '', 'related_field_name' => '', 'post_id' => get_the_ID(), ), $atts, 'acf_relationship' ); $relationship_field = get_field($atts['field_name'], $atts['post_id']); if ($relationship_field) { $output = ''; foreach ($relationship_field as $related_post_id) { $related_field_value = get_field($atts['related_field_name'], $related_post_id); $output .= $related_field_value . ' '; } return $output; } return ''; } add_shortcode('acf_relationship', 'acf_relationship_shortcode');
Then you could use the shortcode inside a headline block eg.
[acf_relationship field_name="your_relationship_field_name" related_field_name="your_related_field_name"]
Can’t say I am 100% confident on that as I don’t do much with ACF relationships but it kinda makes sense 🙂
