ActivityPub plugin’s block elements odd behaviour
    I use the ActivityPub plugin in my WP installation.
    https://wordpress.org/plugins/activitypub/
    I am also the translation editor of the plugin (into Finnish).
    The ActivityPub plugin provides some blocks also.
    Problems with blocks in GeneratePress.
    Example: When I insert Fediverse reactions block in an article, it does not show up in the published article page when using GeneratePress theme. It is visible in the editor but not in the web.
    But when I switch to 2025 factory theme, the block is visible both in the editor and in the published article in the web.
    I’ve informed about this insident in the plugins support forum.
    And now also here.
    There is another issue also in fediverse reactions but I think it is related to the translation strings (maybe).
    Latest WordPress (fi) and GeneratePress premium. All updates up to date.
    Does the plugin only support block based themes?
    Can you try using WP’s twenty-twenty-one theme to test?
  • Hmm..
    I found the problem.
    There must be some conflict with the Webmention plugin. After disabling that, the block works both in GeneratePress and Twenty Twenty One.
  • Glad you did 🙂
