Pryvit
I am trying to add a CSS class to my dynamic content in an element template. However, I’m having trouble adding a CSS class to that content and looking for guidance on how to do it?
My goal is to add a special styling to any H3 tag on my content template element for “Email”. I created a class “.large-h3-margin h3” to handle anything that was inside the large-h3-margin container to have special styling. However, when I add “large-h3-margin” tag to the container that contains the dynamic content block, it doesn’t apply when the page is built.
ie:
inner__section
– content__section (large-h3-margin)
– [dynamic content block]Maybe I’m missing something, but the dynamic content block wont let me add a CSS class to it. I’m sure its simple, I just can’t find it.
Here is the CSS I tried to implement, but wasn’t working.
.large-h3-margin h3 { margin-top: 5rem !important; margin-bottom: 2rem !important; } body.single-email .dynamic-entry-content h3:not(:first-of-type) { margin-top: 5rem !important; margin-bottom: 2rem !important; } -
The CSS should work; if it doesn’t, it’s likely caused by a syntax error in your previous CSS.
Try adding the CSS to the top of the CSS field to test.
Pryvit
Thanks @ying!
In the end it was a coding error in my css. 🤦🏻♂️
But to clarify, can I add CSS directly ‘dynamic-entry-content’ block, or need to put it in a container? is that best practice?
No, the dynamic content block does not have the option to add a CSS class, but why not just use
dynamic-entry-contentclass to write your CSS?Or you can wrap a container outside and add the class to the container.
Pryvit
Thanks.
I am trying to setup a template for a client. So they wouldn’t know how to add the class when writing the content. So ideally its something that automatically happens.
Thanks for all your help!
