TwoLoonSoftware
I have a header element that is applied to a subset of pages, and I need to apply some styling to the header. I’d like to add a class to the merged header (or better, the body element when the header is active).
Is there a way to do this? -
The merged header has a default class
header-wrap
.If you want to target the body, you can do
body:has(.header-wrap)
, if you want to target the header, try.header-wrap .site-header
TwoLoonSoftware
Can I have different classes for different headers?
You can use this snippet:
function my_header_element_body_class($classes) { // ID of your Header Element $header_element_id = 123; // Replace with your actual Header Element ID // Get the element's display conditions $display_conditions = get_post_meta($header_element_id, '_generate_element_display_conditions', true) ?: array(); $exclude_conditions = get_post_meta($header_element_id, '_generate_element_exclude_conditions', true) ?: array(); $user_conditions = get_post_meta($header_element_id, '_generate_element_user_conditions', true) ?: array(); // Check if the Header Element would display on the current page if (class_exists('GeneratePress_Conditions')) { $element_displays = GeneratePress_Conditions::show_data( $display_conditions, $exclude_conditions, $user_conditions ); // If the element would display, add our custom class if ($element_displays) { $classes[] = 'has-header-element'; } } return $classes; } add_filter('body_class', 'my_header_element_body_class');
Simply replace 123 with the header element ID. The snippet will add the
has-header-element
class to the<body>
tag on pages where this element is applied.
