Add classes to the page numbers in query loop pagination
    I have the following class:
    .ca-elevate{
      transition:
        box-shadow var(--ca-transition-m),
        transform var(--ca-transition-m),
        border-colour var(--ca-transition-m);
      will-change: transform, box-shadow;
    I would like to add it to the ‘page numbers’ of the query loop pagination.
    I have tried it with ‘previous’ and “next” and it works fine, but if I add it to the ‘page numbers’ it applies the class to the entire block, but I want it to apply individually to each page number.
    Is this possible?
    Translated with DeepL.com (free version)
  • Hi there.
    Can we see a URL please?
  • I understand that I must have explained myself poorly, because I think the URL is irrelevant…
    Replicating the case is as simple as creating a query loop and adding pagination. It creates three blocks:
    -Previous
    -Page numbers
    -Next
    If you apply a style to the block ‘page numbers,’ it is applied to all the numbers, but I want to apply a style class to the numbers individually.
    I see that each number has the class:
    <a class="page-numbers" href="?query-ab48c320-page=2&cst">2</a>
    How do I add my own class?
    <a class="page-numbers custom-style" href="?query-ab48c320-page=2&cst">2</a>
    Note: it is not necessary to apply a different style to each number, but they do need to have an individual style.
  • A simpler example:
    You have the class:
    .ca-btn–primary {
    background-colour: var(–brand-secondary-2);
    .ca-btn–primary:is(:hover,:focus) {
    background-colour: var(–brand-secondary-1);
    If you apply it to the ‘next’ or ‘previous’ block, it works fine.
    But if you apply it to the ‘page numbers’ block, all the page numbers will change colour at once when you hover over any of them, instead of changing individually when you hover over each one.
    In other words, it goes from this:
    <nav class="ca-btn--primary gb-query-page-numbers-48722d9c">
    <a class="page-numbers" href="?cst">1</a>
    <span aria-current=‘page’ class="page-numbers current">2</span>
    <a class="page-numbers" href="?query-34317618-page=3&cst">3</a></nav>
    to this:
    <nav class="gb-query-page-numbers-48722d9c">
    <a class="ca-btn--primary page-numbers" href="?cst">1</a>
    <a class="ca-btn--primary page-numbers" href="?query-34317618-page=3&cst">3</a></nav>
    All page numbers including the current one all have a page-numbers class assigned to them.
    Query loop pagination markup
    If you select the Page Numbers block, then select the Page Numbers selector, you can style them accordingly. There is also a Hovered Page Number selector, as you can see from the screenshot.
    Page number selectors
    So, depended on what you want to do you can style those selectors.
  • Thank you for your reply, but please read it again and note that the question is not ‘how to add styles’, but ‘how to add a class’.
    Thank you.
    PS: With classes, you don’t have to define styles over and over again. Furthermore, if the style is updated later on, it is easier to modify a class than to modify all the styles individually again.
  • But if you apply it to the ‘page numbers’ block, all the page numbers will change colour at once when you hover over any of them, instead of changing individually when you hover over each one.
    With the method that I showed you, you apply the style once. For example, if you style the Hovered Page Number selector, each page number on hover will be affected.
    You can select the Page Numbers block and assign a class to it, eg: custom-style.
    Page number custom style
    You can then use the .custom-style .page-numbers selector to reference the page numbers.
  • Thank you for responding, but it seems we are not understanding each other.
    With that method, every time you insert a new query loop, you have to reassign the styles. Furthermore, if you want that style to be consistent throughout the website, for example, if you want it to change the colour or shape, you will have to edit all the query loops in the website.
    To achieve consistency, classes are used.
    If, as usual, you have a class to style all the buttons on your website, for example:
    .ca-btn–primary {
    So, you want that style to also apply to the pagination buttons…
    But as I mentioned before, if you assign the class to the ‘Page Numbers’ block, the class affects the block as a whole, not the numbers individually, and when you do, for example, ‘on mouse over’, all the page numbers change colour together, not individually:
    https://drive.google.com/file/d/1_XML_XuNhVv78NT1LkQH6qyJAQcBm-vZ/view?usp=sharing
    the question is: how to add a class that affects to all the “Hovered Page Number” in the website.
  • .ca-btn–primary {
    Just a correction here in case it was not a typo. background-colour should be background-color (American spelling).
    –brand-secondary-2 and –brand-secondary-1 have the wrong dashes — looks like an en-dash followed by a hyphen instead of two hyphens (--)
    It should be like this:
    .ca-btn--primary {
    	background-color: var(--brand-secondary-2);
    .ca-btn--primary:is(:hover, :focus) {
    	background-color: var(--brand-secondary-1);
    In any case, you are trying to create a class that already exists and that class is page-numbers. To target all page-numbers classes in all query loops on the page, you can be more specific, in case there could be other instances of the page-numbers class outside of a query loop in the future.
    .gb-query-loop-pagination .page-numbers
    In the following screencast, I am using this class to affect all hover states of the page numbers for two query loops on the same page, using the following CSS.
    .gb-query-loop-pagination .page-numbers:is(:hover, :focus) {
    	background-color: var(--accent-3);
    View screencast
  • Thank you for correcting the code, but obviously it was just an example, as I told you.
    The class includes background colours, borders, rounding, shadow effects, transform, transition, etc. In other words, the typical elements for defining the style of buttons on a website.
    For EXAMPLE:
    .btn-example {
      display: inline-flex;
      align-items: center;
      justify-content: center;
      gap: .5rem;
      padding: .75rem 1.1rem;
      min-height: 44px;
      font: 600 0.95rem/1 system-ui, -apple-system, Segoe UI, Roboto, Arial, sans-serif;
      letter-spacing: .2px;
      text-decoration: none;
      user-select: none;
      -webkit-tap-highlight-color: transparent;
      color: #ffffff;
      background: #3b82f6;
      border: 1px solid rgba(37, 99, 235, .55);
      border-radius: 14px;
      box-shadow:
        0 10px 22px rgba(2, 6, 23, .10),
        0 2px 6px rgba(2, 6, 23, .08),
        inset 0 1px 0 rgba(255, 255, 255, .18);
      transition:
        transform 160ms ease,
        box-shadow 160ms ease,
        background 220ms ease,
        border-color 220ms ease,
        color 220ms ease,
        filter 220ms ease;
      will-change: transform;
      cursor: pointer;
      position: relative;
      overflow: hidden;
    .btn-example::before {
      content: "";
      position: absolute;
      inset: 0;
      border-radius: inherit;
      background: radial-gradient(120px 60px at 20% 0%,
          rgba(255, 255, 255, .35),
          rgba(255, 255, 255, 0) 60%);
      opacity: .9;
      pointer-events: none;
    .btn-example:hover {
      transform: translateY(-2px);
      background: #2563eb;
      border-color: rgba(29, 78, 216, .75);
      box-shadow:
        0 14px 30px rgba(2, 6, 23, .14),
        0 3px 10px rgba(2, 6, 23, .10),
      filter: saturate(1.05);
    .btn-example:active {
      transform: translateY(0px) scale(0.99);
      box-shadow:
        0 8px 16px rgba(2, 6, 23, .12),
        0 2px 6px rgba(2, 6, 23, .10),
        inset 0 2px 8px rgba(2, 6, 23, .18);
    .btn-example:focus-visible {
      outline: 3px solid rgba(59, 130, 246, .55);
      outline-offset: 3px;
    .btn-example:disabled,
    .btn-example[aria-disabled="true"] {
      opacity: .55;
      cursor: not-allowed;
      transform: none;
      filter: none;
    But the content of the class is not relevant.
    And by the way, –brand-secondary-1 is perfectly valid with a single dash (using two dashes is just a convention that has no effect). Still, thank you very much for taking the time to try to correct it.
    Sorry, It seems you’re still not reading the messages carefully… but never mind, I’ll repeat it again:
    The class for styling buttons doesn’t exist, which is why it’s being created to apply styling to all the buttons on the website.
    I really appreciate all the information you are giving me about the content of the pagination, its classes, how to apply styles, selectors, etc., but that is not what I am asking.
    The question is:
    How can I apply a class (the one I use for the buttons on the website) to the buttons on the query loop pagination?
    I hope that clarifies the issue.
    Thank you.
  • How can I apply a class (the one I use for the buttons on the website) to the buttons on the query loop pagination?
    Ok, I think I see now. You want to use the existing class you have already created.
    You would need to use the render_block filter to modify the markup of all query loops on the page and append your selected class next to the page-numbers class.
    add_filter( 'render_block', function( $block_content, $block ) {
        // Target only the GenerateBlocks Page Numbers block
        if ( 'generateblocks/query-page-numbers' === $block['blockName'] ) {
            // Add your class to all page-numbers elements (both <a> and <span>)
            $block_content = str_replace(
                'class="page-numbers',
                'class="page-numbers btn-example',
                $block_content
        return $block_content;
    }, 10, 2 );
    This code will append the btn-example class next to the existing page-numbers class.
    Let me know if I got it right this time!
  • Okay, that would work.
    Although it’s a bit surprising that Generateblock (which allows you to do a thousand things in CSS styles!) doesn’t allow you to add classes to page numbers…
    Thank you
  • Yeah, I see what you mean. You can insert classes in the block level but obviously this cannot go so as deep as you want sometimes, that’s why using filters can be a good way to extend functionality.
    Anyway, you are welcome and thanks for your patience on this.
  • From my point of view, I find it very limiting that there is only one block called ‘page numbers’ and that you have to play around with selectors.
    It’s as if in the query loop you could only assign classes to the entire ‘looper’ and not to the ‘loop item’…
    Even so, GP and GB are the best there is.
  • Yes, I see what you mean. You can also post a feature request here about it:
    https://feedback.generatepress.com
    I think so too!
Viewing 15 posts - 1 through 15 (of 15 total)
