mafsdisseny
Okay, according to this topic:
https://generate.support/topic/query-loop-full-content-and-word-count/It is not possible to add the full content (not just the excerpt) into a query loop block. But I can’t believe there isn’t an easy solution to achieve this. Changing the excerpt length is not an option because I need to output a button (and maybe other blocks that are inside the content), and when you choose ‘excerpt’ it returns only plain text…
How can I proceed? Maybe I will need to create a shortcode? But, if this has to be the option, can I create a shortcode from the elements section and call it? Or will I need to get my hands dirty and write code in the functions file, and then call the shortcode?
BTW, I’m working on an static page that have other loops showing content from different CPTs, so this is not an archive page.
Can you please guide me on how to achieve it? Thanks.
the issue arises from WordPress restricting access to the core
Post Content
block. So what was an easy thing to do by virtue of the core blocks code, is now a bit of a pain.I can ‘t guarantee this will work but you could try this:
1. Add this PHP Snippet to your site.
It has to be a functions.php in your child theme or via a code snippets pluginadd_filter( 'render_block', function( $block_content, $block ) { if (is_admin() || wp_is_json_request()) { return $block_content; } // variable to track the state and prevent infinite loops static $inside_loop = false; if ($inside_loop) { return $block_content; } if ( ! empty( $block['attrs']['className'] ) && 'show-post-content' === $block['attrs']['className'] ) { global $post; $inside_loop = true; $post_content = apply_filters('the_content', $post->post_content); $inside_loop = false; return $post_content; } return $block_content; }, 10, 2 );
2. add a Headline block as a placeholder in your loop, and give the headline an Advanced > Additional CSS Class of:
show-post-content
Which is the class we specify in the snippet.On the front end this “should” render the post content in full.
mafsdisseny
Okay! It’s almost perfect!
Why is it not returning any style given (in the backend) to the headline placeholder block?
Ideally, I want to assign some style from the backend to this headline block, i.e., font size and line height, maybe color… Is it possible?
I guess that with this code you are replacing the whole content that the block contains, but maybe there is a way to keep the style declared in the frontend? -
The most you could do is to place the headline inside a container block.
And on the container block set the font styles and perhaps color for the textIf the post content is inheriting its font size and color from the body ( which is the default behaviour for the GP theme ) it would not inherit them from that container block.
mafsdisseny
Okay, thank you. I hope you can integrate this functionality into the core GP and GB.
As always, the experience with your support service is wonderful. I’m happy to trust in GP! -
You’re welcome
mafsdisseny
