Add custom fonts without Font library
  • Hello there, I am trying to add a new font family in the Typography dropdown menu. I have followed this code but it seems that is not working.
    https://docs.generateblocks.com/article/add-custom-fonts-to-font-family-dropdown-list/
    Note that i am not using GeneratePress in order to use Font Library, I am just using GenerateBlocks with a custom theme.
    Any help would be much appreciated.
    The filter was for v1 GB blocks. Are you using v2 blocks?
  • Hello, yes i am using v2 of blocks.
    The filter should still work. Have you installed the font you want to add to the block typography settings on your site?
  • I am not sure how to do this.
  • You mentioned using a custom theme. Does the theme have a Typography option, usually found in the Customizer?
  • I am registering fonts in the head like this
    and after this I am using the fonts in the css variables like this:
    :root {
    --my-font: 'Poppins';
    The css file which contains the variables is loaded also in the Gutenberg editor via the enqueue_block_editor_assets action in order to use the variables in the backend and the font this way is working if I use the variable rule but for the end users is more friendly to have the font in the dropdown menu from start thats why I am trying to register also my font to the Typography dropdown.
  • I checked with the dev team, and they confirm that the GB filter has a bug, it currently doesn’t work, unfortunately!
  • Nice to hear that is not my mistake. Can we expect a fix on this on a later version?
  • If it’s a simple fix, it should be possible to include it in the next minor update.
    You can stay up to date with the issue here: https://github.com/tomusborne/generateblocks/issues/1790
  • Hey there,
    I use this plugin for managing fonts and ran into this v2 blocks bug https://webfont.yabe.land/
    Any update on when a fix will be available?
    I actually found this bug a couple months ago but assumed it was a problem with the other plugin rather than GB.
