MikeB82
How do I add these Google Tag Manager scripts to GeneratePress?
There are two scripts.
1. Paste this code as high in the <head> of the page as possible:
<!– Google Tag Manager –>
<script>(function(w,d,s,l,i){w[l]=w[l]||[];w[l].push({‘gtm.start’:
new Date().getTime(),event:’gtm.js’});var f=d.getElementsByTagName(s)[0],
j=d.createElement(s),dl=l!=’dataLayer’?’&l=’+l:”;j.async=true;j.src=
‘https://www.googletagmanager.com/gtm.js?id=’+i+dl;f.parentNode.insertBefore(j,f);
})(window,document,’script’,’dataLayer’,’GTM-5Z3VV7MK’);</script>
<!– End Google Tag Manager –> -
You can use a Hooks Element to add it.
Go to Appearance > Elements and create a new Hook Element.
Paste the script into the content area. Then, under the Settings panel, configure the following:
Hook: wp_head
Priority: 1Under Display Rules, set the location to Entire Site.
MikeB82
Thanks for this information.
There’s a 2nd script that didn’t go through in my first post.
2. Paste this code immediately after the opening <body> tag:
<!– Google Tag Manager (noscript) –>
<noscript><iframe src=”https://www.googletagmanager.com/ns.html?id=GTM-5Z3VV7MK”
height=”0″ width=”0″ style=”display:none;visibility:hidden”></iframe></noscript>
<!– End Google Tag Manager (noscript) –> -
The second script needs to use a different hook.
Create a separate Hook Element for it, and set the hook to wp_body_open instead.
MikeB82
Thanks! GeneratePress Elements are great!
You’re welcome!
