Add hover color to button with background gradient
    I use the GP buttons with the native background-gradient feature as a global style.
    How can I add a single color as hover color to this gradient button?
    I tried some CSS hacks as additional CSS in the advanced section. But nothing worked out.
    Do you have any idea for me?
    Thanks in advance,
    Matthias
    can you share a link to where i can see the button ?
  • Ah your gradient is using one of the themes CSS colors.
    So you could do this:
    1. give the button a CSS Class of: gradient-button
    2. Add this CSS:
    .gradient-button:hover {
        --primary: #f00;
    What that does is swaps the --primary color value just for that button on hover.
    If both colors in the gradient were a CSS variable color then you could do both.
  • It works quite well with the Primary color code:
        --primary: #065299;
    But can you please advice how the CSS should look like, if I also want to swap the second color of the gradient which is a CSS code (#0957CB)?
  • 1. Go to Customizer > Colors and add another global color for the 2nd gradient color.
    For the example we will call it gradient-start
    This will create a. CSS variable of --gradient-start: #f00;
    Then you can update the CSS:
        --primary: #065299;
        --gradient-start: #00f;
  • Thanks David, works pretty well 🙂
  • You’re welcome
