Anonymous
Hello support-team,
How can I add a loop for all category pages based on taxonomy and keywords.
The loop should filter on fixed keywords e.g. top-1, top-2 and top-3 and also take into account the internal category of the category page e.g. “Berlin”.
Is this easy to solve with standard functionality in GeneratePress?
Kind regards
Jens -
I don’t think keywords would work in this case, you might need to create tags like
top-posts
, and assign the posts to that tag.Then you can set the query loop to taxonomy > category > current category, and add taxonomy > tag > top-posts.
However, please note that the current category option is a GB Pro option.
Anonymous
Hi Ying,
then I’ll try using post tags.
But how do I get an additional loop on all category pages with my top-1 to top-3 tagsThe goal is to add a separate loop to all category pages, e.g.:
https://www.museum-ticket.info/de/standorte/deutschland/museen-potsdam/In addition to the standard loop, which also takes the tags into account.
Do I have to extend this in the archive.php or use a hook?
Do you have an example for me?Kind regards
Jens -
Can you provide more context on how this additional query loop is expected to function? Does it act as a filtering mechanism, where selecting a top tag dynamically queries and loads the related posts for that taxonomy term, with the same behavior applied to other tags?
Anonymous
Hi Alvind,
I’m happy to add my information. 🙂
The goal is to structure all category pages uniformly.– H1 headline
– Feature image
– Custom content via custom field on the category
– Custom loop (top list) with internal taxonomy + tags (Top1, Top2, Top3)
– Standard category loop with internal taxonomyThe custom loop that I would like to add to the category page. So I would have to use the taxonomy of the internal category and also filter on my tags (Top1, Top2, Top3).
Is that easy to do?
At the moment I find it very difficult to adapt the category page.
So generally, you will create a block element – loop template to add all this content and assign it to category archives.
As for the 2 loops, what do you mean by internal taxonomy? Do you mean the child categories of the current category?
