Add purchease script to a page
  • klintensiv2021
    how can I add a google purchease script to thank you page with elements?
    Page: https://klintensiv.ro/checkout/order-received/
    Script:
    <!– Event snippet for Achizitii Site conversion page –>
    <script>
    gtag(‘event’, ‘conversion’, {
    ‘send_to’: ‘AW-798760367/PbC3CM644ckCEK-78PwC’,
    ‘value’: 1.0,
    ‘currency’: ‘RON’,
    ‘transaction_id’: ”
    </script>
    Thank you!
    Costin
    in Appearance > Elements -> Add New –> HOOK, see here:
    https://docs.generatepress.com/article/hooks-element-overview/
    Add your script to the text area.
    Set the Display Rules to the site locations where you require ie eg. Entire Site
    Then set the Hook to either:
    a. wp_head for adding the code to the site <head>
    b. wp_footer for adding the code to the site <footer>
  • klintensiv2021
    Thx. I need the hook, only on a specific page.
    This page: https://klintensiv.ro/checkout/order-received/
    How can I do dhis?
    Thank you!
    You can set that in the Element’s Location settings. Instead of Entire Site, choose Page and select the order received page.
  • klintensiv2021
    hi, I did not have an order recieve page in the element list.
    This page (https://klintensiv.ro/checkout/order-received/) is automatet created by woocomerce.
    Also, I need to insert value of order in this page.
    <!-- Event snippet for Achizitii Site conversion page -->
    <script>
      gtag('event', 'conversion', {
          'send_to': '',
          'value': 1.0,
          'currency': 'RON',
          'transaction_id': ''
    </script>
  • You would need to use a PHP snippet to do that:
    // Add the script to the head section of the order-received page
    function add_conversion_tracking_script() {
        // Check if it's the order-received page
        if (is_wc_endpoint_url('order-received')) {
            // Get the current order ID
            $order_id = absint( get_query_var('order-received') );
            // Check if order ID is valid
            if ($order_id > 0) {
                // Get the order object
                $order = wc_get_order($order_id);
                // Get the transaction ID
                $transaction_id = $order->get_order_number();
                // Output the script with transaction ID
                <script>
                        'send_to': '',
                        'value': 1.0,
                        'currency': 'RON',
                        'transaction_id': '<?php echo esc_js($transaction_id); ?>'
                </script>
                <?php
    add_action('wp_head', 'add_conversion_tracking_script');
