madhavan1
There are various opinions on how to add a search box or icon to the right of the primary navigation. None of these options has worked for me.
Is there a straightforward way to do this for a non-block editor site? The location is: http://www.awarenessthatheals.org
Thank you.
did you try the Navigation Search Modal in Customizer > Layout > Primary Navigation
madhavan1
Yes, David, that is the first option I tried.
Can you check in Appearance > Customize > General, if there’s an option there to switch from the Float System to the Flexbox system? Reference: https://docs.generatepress.com/article/switching-from-floats-to-flexbox/
If so, try switching – It would be best to backup your site though before doing this.
madhavan1
I made the switch to the Flexbox system, Fernando. I also confirmed that the “Enable navigation search modal” option is checked. Cleared local and CDN cache. Still no search box.
It’s there but the SVG isn’t showing. I wonder if a third-party or you have a code in your Child theme is causing it not to show
Can you try switching to the Parent theme? And, if this doesn’t work, can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
It’s recommended to backup your site before proceeding with this.
madhavan1
The implication of changing to the Pareent theme when we are about to launch a new series makes me a bit uncomfortable. Also, after changing to the Flexbox system, the podcast page begins to indent at the 5th entry down on the page. That page is here: https://www.awarenessthatheals.org/awareness-that-heals-podcast/
Your thoughts?
Can you go to customizer > general, if you are using fonts, switch it to svg.
madhavan1
Thank you, Ying! That was exactly the problem. Greatly appreciated.
Last item: Any reason why, around the 5th blog post the alignment is off? That page is here: https://www.awarenessthatheals.org/awareness-that-heals-podcast/
You seem to be using a third-party plugin to Query Posts on this page. It would be best to reach out to their support regarding this alignment issue.
madhavan1
Okay, thank you.
madhavan1
Actually, it is the GeneratePress posts plugin.
It’s built with Ultimate Addons for Beaver Builder upon checking.
madhavan1
Yes, you are correct. I was thinking of another site.
Thanks again for the very quick response. Always appreciated.
You’re welcome!
