jrmora
Hi, I need a little help
Subject:
Small aesthetic customization of search results page using Query Loop / Loop Template and a Layout to remove sidebar. Everything went well although I didn’t manage to add some things.Here you can see:
https://jrmora.com/?s=testContext in this thread:
https://generate.support/topic/first-steps-to-create-custom-search-results-page/Now I need a help to add in the search loop with a hook Element the sentence “Showing results (X Number) for: ( searched word)” because I can’t find the correct syntax in search.php (I understand it’s called from another site).
Regards
it will require some PHP.
1. Add this PHP snippet to your site:
add_filter( 'render_block', function( $block_content, $block ) { if ( !is_admin() && is_search() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'search-title' ) !== false ) { global $wp_query; $found_posts = $wp_query->found_posts; if ( $found_posts ) { if ( $found_posts > 1 ) { $block_content = sprintf( __( 'Showing %1$s Results for: "%2$s"', 'generatepress' ), $found_posts, '<span>' . get_search_query() . '</span>' ); } elseif ( $found_posts === 1 ) { $block_content = sprintf( __( 'Showing 1 Result for: "%1$s"', 'generatepress' ), '<span>' . get_search_query() . '</span>' ); } } } return $block_content; }, 10, 2 );
2. in your Element add a Headline block with some static text for you search title and give it a CSS Class of:
search-title
jrmora
Hi, David.
Great! It works just as it should. Appreciate it.
Now I’m going to keep fighting with the reading time and the hit counter.
Thank you very much.
You’re welcome
