huppap
Hi I am trying to add a smooth scroll class to customer review anchor right by the product title.
I checked in inspect element if I added the class to anchor like this it does what I am trying to do.
From
<a href="#reviews" class="woocommerce-review-link" rel="nofollow">(<span class="count">1</span> customer review)</a>to
<a href="#reviews" class="woocommerce-review-link smooth-scroll" rel="nofollow">(<span class="count">1</span> customer review)</a>But I am not sure how to add this class via a code.
I tried method explained not think link and added this code and it did not solve it.
https://docs.generatepress.com/article/add-a-custom-class-to-the-body-element/
add_filter( 'woocommerce-review-link','tu_add_body_class' ); function tu_add_body_class( $classes ) { $classes[] = 'smooth-scroll'; return $classes; } -
Try this PHP code which automatically smooth-scroll all anchor links.
add_filter( 'generate_smooth_scroll_elements', function( $elements ) { $elements[] = 'a[href*="#"]'; return $elements; } ); -
huppap
awesome. thank you!
huppap
is it possible to add that class only to the link I want and not to everywhere?
Yes, in that case, you can add each of the class:
add_filter('generate_smooth_scroll_elements', function () { $classes = array('.woocommerce-review-link','.another-class'); return $classes; });in the above code, it adds the element with
woocommerce-review-linkclass and elements with classanother-classto the smooth scroll element list.If you want more elements to smooth scroll, just replace
another-classwith the actual class, and you can keep on adding it.But be careful, if you have more than one elements that have the class
woocommerce-review-link, all of them will be smooth-scrolled. Hope that makes sense! -
huppap
Thank you so much!
