gandalf12
I have created a block element with element type site header and added Header 1 from the pattern library.
I want to add a search bar and social media icons to the right hand end of the menu items.
I created a new Hook element with the social media icons in it and hook name menu-bar-items, but it does not appear and I could not get it to appear using any of the other hook names in navigation.
I guesss I am approaching this in the wrong way and would like some guidance please, also on how to add the search box.
You can add the social icon to the site header element directly instead of creating a new hook element, as the
menu_bar_itemshook does not exist in the custom site header.If so, you can create a button in the site header element and fill the custom attribute as the doc introduced:
https://docs.generatepress.com/article/navigation-search-modal/#add-custom-navigation-search-modal-triggerJust make sure the Navigation search modal is enabled at customizer > layout > navigation.
gandalf12
Hi Ying,
I have added the search and social icons using buttons, but I cannot find where to add the custom attribute, the only one I could find was HTML Attribute.
Can you advise please
Yes, the HTML attribute in the advanced panel of GB blocks.
https://learn.generatepress.com/blocks/block-guide/getting-started-generateblocks/generateblocks-pro/html-attributes-builder/ -
gandalf12
I tried that by adding data-gpmodal-trigger= in the Name box and “gp-search” in the value but it did not work.
Add
data-gpmodal-triggerwithout the=.And did you enable the search modal in the customizer?
gandalf12
Hi Ying,
Once again many thanks, it was the = that was stopping it from working, all good now.
Richard
