ISTM2026
Hi, I’m transitioning from Divi to GeneratePress. I build my own business websites, but am not a coder or developer. In the past, I’ve been able to take sections or full pages of one template (Uncode, Divi, etc) and add them to my existing template. Is this possible on GeneratePress? Ny site is atypical and the sections of standard templates usually need to be heavily tweaked. I also don’t want to load up on plugins due to the annoyance/maintenance factor and bogging down site speed. Any help appreciated during this steep learning curve! Thnx
You can not import one page or one section from the site library, but if you can tell me which section/page you are referring to, I can get the code for you, and you can paste it to a new page editor.
But since it’s not a full site import, the page will look different from its original state.
ISTM2026
I’m having a lot of trouble working with this. I tried pasting my live site’s home page html in, and that didn’t work. And I wanted to add the front page of the “Construction” theme to my new site, but can’t seem to make that work. Thanks for any help you can provide
Using an individual section from the Site Library on an existing site may not work as expected for a few reasons.
Most starter sites rely heavily on Global Styles. When you copy or import a single section, those global styles are not included, so the styling may not match the original design.
Additionally, starter sites are built using multiple templates — the header, footer, and homepage are usually managed by separate Elements. If you only import the homepage section, the corresponding header and footer will not be applied automatically.
That said, you can still reuse the basic layout structure of the homepage, but you should expect to make some manual adjustments to match the original design.
If you’d like to proceed anyway, you can do the following:
– Create a new draft page
– Paste the following block template markup into the page:<!-- wp:generateblocks/element {"uniqueId":"7dc5b091","tagName":"section","styles":{"backgroundColor":"var(\u002d\u002dcontrast-3)","position":"relative","overflowX":"hidden","overflowY":"hidden","textAlign":"center","backgroundImage":"linear-gradient(to left, rgba(38, 38, 38, 0.52) 0%, rgba(38, 38, 38, 0.52) 100%),url(https://playground.alvind.com.my/wp-content/uploads/2021/12/jeriden-villegas-VLPUm5wP5Z0-unsplash.jpg)","backgroundSize":"cover,cover","backgroundRepeat":"no-repeat,no-repeat","backgroundPosition":"center,center","backgroundBlendMode":"normal,normal"},"css":".gb-element-7dc5b091{background-blend-mode:normal,normal;background-color:var(\u002d\u002dcontrast-3);overflow-x:hidden;overflow-y:hidden;position:relative;text-align:center;background:linear-gradient(to left,rgba(38,38,38,0.52) 0%,rgba(38,38,38,0.52) 100%),url(https://playground.alvind.com.my/wp-content/uploads/2021/12/jeriden-villegas-VLPUm5wP5Z0-unsplash.jpg) center /cover no-repeat}","htmlAttributes":[],"metadata":[]} --> <section class="gb-element-7dc5b091"><!-- wp:generateblocks/element {"uniqueId":"0e8bc3cd","tagName":"div","styles":{"@media (max-width:1024px)":{"paddingTop":"150px","paddingBottom":"150px"},"@media (max-width:767px)":{"paddingTop":"100px","paddingRight":"30px","paddingBottom":"100px","paddingLeft":"30px"},"position":"relative","zIndex":"1","maxWidth":"var(\u002d\u002dgb-container-width)","paddingTop":"200px","paddingRight":"40px","paddingBottom":"200px","paddingLeft":"40px","marginRight":"auto","marginLeft":"auto"},"css":".gb-element-0e8bc3cd{margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);position:relative;z-index:1;padding:200px 40px}@media (max-width:1024px){.gb-element-0e8bc3cd{padding-bottom:150px;padding-top:150px}}@media (max-width:767px){.gb-element-0e8bc3cd{padding:100px 30px}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-0e8bc3cd"><!-- wp:generateblocks/text {"uniqueId":"568819bf","tagName":"h1","styles":{"display":"flex","flexDirection":"column","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"1em","height":"1em"},"rowGap":"8px"},"css":".gb-text-568819bf{color:var(\u002d\u002dbase-2);display:flex;flex-direction:column;row-gap:8px}.gb-text-568819bf .gb-shape svg{width:1em;height:1em}","htmlAttributes":[],"metadata":[],"className":"home-heading"} --> <h1 class="gb-text-568819bf home-heading"><span class="gb-shape"><svg viewBox="0 0 220.805 220.805" xmlns="http://www.w3.org/2000/svg"><path fill="CurrentColor" d="M205.402 220.805h-190a4 4 0 0 1-4-4V42.001a4 4 0 0 1 2.515-3.714l95-38.002a3.998 3.998 0 0 1 5.486 3.714v76.097l89.515-35.808a3.998 3.998 0 0 1 5.486 3.714v168.803a4.003 4.003 0 0 1-4.002 4zm-91-8h87V53.91l-87 34.802v124.093zm-95 0h87V9.907l-87 34.802v168.096zm165.333-10.972a4 4 0 0 1-4-4V162.21h-18.833v35.623a4 4 0 0 1-8 0V162.21h-18.833v35.623a4 4 0 0 1-8 0v-93.332a4 4 0 0 1 8 0v15.124h18.833v-27.79a4 4 0 0 1 8 0v27.79h18.833V82.251a4 4 0 0 1 8 0v115.582a4 4 0 0 1-4 4zm-22.833-47.623h18.833v-26.585h-18.833v26.585zm-26.833 0h18.833v-26.585h-18.833v26.585zm-45.334 47.623a4 4 0 0 1-4-4v-35.831H66.902v35.831a4 4 0 0 1-8 0v-35.831H40.069v35.831a4 4 0 0 1-8 0V61.667a4 4 0 0 1 8 0v23.166h18.833V49.002a4 4 0 0 1 8 0v35.831h18.833V39.417a4 4 0 0 1 8 0v158.416a4 4 0 0 1-4 4zm-22.833-47.831h18.833v-26.585H66.902v26.585zm-26.833 0h18.833v-26.585H40.069v26.585zm26.833-34.585h18.833V92.833H66.902v26.584zm-26.833 0h18.833V92.833H40.069v26.584z"></path></svg></span><span class="gb-text">Construction</span></h1> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/element {"uniqueId":"c84ef5cd","tagName":"div","styles":{"display":"flex","alignItems":"center","columnGap":"20px"},"css":".gb-element-c84ef5cd{align-items:center;column-gap:20px;display:flex}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-c84ef5cd"><!-- wp:generateblocks/element {"uniqueId":"6d018522","tagName":"div","styles":{"backgroundColor":"var(\u002d\u002dbase-2)","flexGrow":"1","minHeight":"1px"},"css":".gb-element-6d018522{background-color:var(\u002d\u002dbase-2);flex-grow:1;min-height:1px}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-6d018522"></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"40345347","tagName":"p","styles":{"@media (max-width:767px)":{"display":"flex","textAlign":"center"},"display":"flex","justifyContent":"center","fontSize":"14px","letterSpacing":"0.2em","textTransform":"uppercase","textAlign":"center","marginRight":"auto","marginBottom":"0px","marginLeft":"auto","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-40345347{color:var(\u002d\u002dbase-2);display:flex;font-size:14px;justify-content:center;letter-spacing:0.2em;margin-bottom:0px;margin-left:auto;margin-right:auto;text-align:center;text-transform:uppercase}@media (max-width:767px){.gb-text-40345347{display:flex;text-align:center}}","htmlAttributes":[],"metadata":[],"className":"home-heading"} --> <p class="gb-text gb-text-40345347 home-heading">Construction consultants</p> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/element {"uniqueId":"9eef342b","tagName":"div","styles":{"backgroundColor":"var(\u002d\u002dbase-2)","flexGrow":"1","minHeight":"1px"},"css":".gb-element-9eef342b{background-color:var(\u002d\u002dbase-2);flex-grow:1;min-height:1px}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-9eef342b"></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"03b453fc","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"display":"inline-flex","alignItems":"center","justifyContent":"center","fontWeight":"700","textTransform":"capitalize","textAlign":"center","paddingTop":"16px","paddingRight":"30px","paddingBottom":"16px","paddingLeft":"30px","marginTop":"80px","borderTopRightRadius":"3px","borderBottomRightRadius":"3px","borderBottomLeftRadius":"3px","borderTopLeftRadius":"3px","backgroundColor":"var(\u002d\u002dbase-2)","color":"var(\u002d\u002dcontrast-3)",".gb-shape svg":{"width":"0.9em","height":"0.9em","fill":"currentColor"},"textDecoration":"none","columnGap":"1em"},"css":".gb-text-03b453fc{align-items:center;background-color:var(\u002d\u002dbase-2);color:var(\u002d\u002dcontrast-3);column-gap:1em;display:inline-flex;font-weight:700;justify-content:center;margin-top:80px;text-align:center;text-decoration:none;text-transform:capitalize;border-radius:3px;padding:16px 30px}.gb-text-03b453fc:is(:hover,:focus){background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2)}.gb-text-03b453fc .gb-shape svg{width:0.9em;height:0.9em;fill:currentColor}","htmlAttributes":{"href":"https://sites.generatepress.com/construction/projects/"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-03b453fc" href="https://sites.generatepress.com/construction/projects/"><span class="gb-text">View projects</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --></section> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"7bc404d1","tagName":"section","styles":{"@media (max-width:1024px)":{"columnGap":"40px"},"@media (max-width:767px)":{"flexDirection":"column","rowGap":"80px","paddingTop":"60px","paddingRight":"30px","paddingLeft":"30px"},"display":"flex","columnGap":"60px","maxWidth":"var(\u002d\u002dgb-container-width)","paddingTop":"100px","paddingRight":"40px","paddingBottom":"100px","paddingLeft":"40px","marginRight":"auto","marginLeft":"auto"},"css":".gb-element-7bc404d1{column-gap:60px;display:flex;margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);padding:100px 40px}@media (max-width:1024px){.gb-element-7bc404d1{column-gap:40px}}@media (max-width:767px){.gb-element-7bc404d1{flex-direction:column;padding-left:30px;padding-right:30px;padding-top:60px;row-gap:80px}}","htmlAttributes":[],"metadata":[]} --> <section class="gb-element-7bc404d1"><!-- wp:generateblocks/element {"uniqueId":"f7f3cb9c","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"width":"50%"},"css":".gb-element-f7f3cb9c{width:50%}@media (max-width:767px){.gb-element-f7f3cb9c{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-f7f3cb9c"><!-- wp:generateblocks/text {"uniqueId":"c1ab295a","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em"},"columnGap":"0.5em"},"css":".gb-text-c1ab295a{align-items:center;color:var(\u002d\u002daccent);column-gap:0.5em;display:flex;font-size:16px}.gb-text-c1ab295a .gb-shape svg{width:1em;height:1em}@media (max-width:767px){.gb-text-c1ab295a{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text-c1ab295a"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 448 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M16 132h416c8.837 0 16-7.163 16-16V76c0-8.837-7.163-16-16-16H16C7.163 60 0 67.163 0 76v40c0 8.837 7.163 16 16 16zm0 160h416c8.837 0 16-7.163 16-16v-40c0-8.837-7.163-16-16-16H16c-8.837 0-16 7.163-16 16v40c0 8.837 7.163 16 16 16zm0 160h416c8.837 0 16-7.163 16-16v-40c0-8.837-7.163-16-16-16H16c-8.837 0-16 7.163-16 16v40c0 8.837 7.163 16 16 16z"></path></svg></span><span class="gb-text">Leading the way</span></h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"2d03a280","tagName":"h2","styles":[],"htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text">Let's build a better world together</h2> <!-- /wp:generateblocks/text --> <!-- wp:paragraph --> <p>In sodales nibh nec purus porttitor molestie. Cras id erat tincidunt arcu viverra pretium fringilla nec velit. Sed porta tincidunt eros at sagittis. Integer et cursus nibh.</p> <!-- /wp:paragraph --> <!-- wp:paragraph --> <p>Aenean maximus imperdiet facilisis. Phasellus convallis ante et lectus auctor suscipit.</p> <!-- /wp:paragraph --> <!-- wp:generateblocks/element {"uniqueId":"43426afc","tagName":"div","styles":{"@media (max-width:1024px)":{"flexDirection":"column"},"display":"flex","columnGap":"40px"},"css":".gb-element-43426afc{column-gap:40px;display:flex}@media (max-width:1024px){.gb-element-43426afc{flex-direction:column}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-43426afc"><!-- wp:generateblocks/element {"uniqueId":"4c1f8ca2","tagName":"div","styles":{"@media (max-width:1024px)":{"width":"100%"},"@media (max-width:767px)":{"width":"100%"},"width":"50%"},"css":".gb-element-4c1f8ca2{width:50%}@media (max-width:1024px){.gb-element-4c1f8ca2{width:100%}}@media (max-width:767px){.gb-element-4c1f8ca2{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-4c1f8ca2"><!-- wp:generateblocks/text {"uniqueId":"0ad73597","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-0ad73597{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-0ad73597 .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-0ad73597{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-0ad73597"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Project planning</span></h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"06572523","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-06572523{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-06572523 .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-06572523{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-06572523"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Interior design</span></h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"a17e1070","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-a17e1070{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-a17e1070 .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-a17e1070{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-a17e1070"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Budget planning</span></h3> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"fa6c58d2","tagName":"div","styles":{"@media (max-width:1024px)":{"width":"100%"},"@media (max-width:767px)":{"width":"100%"},"width":"50%"},"css":".gb-element-fa6c58d2{width:50%}@media (max-width:1024px){.gb-element-fa6c58d2{width:100%}}@media (max-width:767px){.gb-element-fa6c58d2{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-fa6c58d2"><!-- wp:generateblocks/text {"uniqueId":"df1dd570","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-df1dd570{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-df1dd570 .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-df1dd570{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-df1dd570"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Solid waste removal</span></h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"e83ad7ad","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-e83ad7ad{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-e83ad7ad .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-e83ad7ad{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-e83ad7ad"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Accurate testing processes</span></h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"172c4579","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","alignItems":"center","fontSize":"16px","textTransform":"capitalize","marginBottom":"14px",".gb-shape svg":{"color":"var(\u002d\u002daccent)","fill":"currentColor","width":"1em","height":"1em"},"columnGap":"1em"},"css":".gb-text-172c4579{align-items:center;column-gap:1em;display:flex;font-size:16px;margin-bottom:14px;text-transform:capitalize}.gb-text-172c4579 .gb-shape svg{color:var(\u002d\u002daccent);fill:currentColor;width:1em;height:1em}@media (max-width:767px){.gb-text-172c4579{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text-172c4579"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 512 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M504 256c0 136.967-111.033 248-248 248S8 392.967 8 256 119.033 8 256 8s248 111.033 248 248zM227.314 387.314l184-184c6.248-6.248 6.248-16.379 0-22.627l-22.627-22.627c-6.248-6.249-16.379-6.249-22.628 0L216 308.118l-70.059-70.059c-6.248-6.248-16.379-6.248-22.628 0l-22.627 22.627c-6.248 6.248-6.248 16.379 0 22.627l104 104c6.249 6.249 16.379 6.249 22.628.001z"></path></svg></span><span class="gb-text">Highly qualified</span></h3> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"ace03398","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-2)"},"display":"inline-flex","alignItems":"center","justifyContent":"center","fontWeight":"700","textTransform":"capitalize","textAlign":"center","paddingTop":"16px","paddingRight":"30px","paddingBottom":"16px","paddingLeft":"30px","marginTop":"40px","borderTopRightRadius":"3px","borderBottomRightRadius":"3px","borderBottomLeftRadius":"3px","borderTopLeftRadius":"3px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"0.9em","height":"0.9em","fill":"currentColor"},"textDecoration":"none","columnGap":"1em"},"css":".gb-text-ace03398{align-items:center;background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);column-gap:1em;display:inline-flex;font-weight:700;justify-content:center;margin-top:40px;text-align:center;text-decoration:none;text-transform:capitalize;border-radius:3px;padding:16px 30px}.gb-text-ace03398:is(:hover,:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-2)}.gb-text-ace03398 .gb-shape svg{width:0.9em;height:0.9em;fill:currentColor}","htmlAttributes":{"href":"https://sites.generatepress.com/construction/projects/"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-ace03398" href="https://sites.generatepress.com/construction/projects/"><span class="gb-text">Latest projects</span><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 44.952 44.952"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"eea4ea26","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"width":"50%"},"css":".gb-element-eea4ea26{width:50%}@media (max-width:767px){.gb-element-eea4ea26{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-eea4ea26"><!-- wp:generateblocks/element {"uniqueId":"16f5ad3a","tagName":"div","styles":{"display":"grid","gridTemplateColumns":"repeat(2, minmax(0, 1fr))","columnGap":"20px","rowGap":"20px","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))","columnGap":"","rowGap":""},"@media (max-width:767px)":{"gridTemplateColumns":"","columnGap":"","rowGap":"40px"}},"css":".gb-element-16f5ad3a{column-gap:20px;display:grid;grid-template-columns:repeat(2,minmax(0,1fr));row-gap:20px}@media (max-width:1024px){.gb-element-16f5ad3a{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (max-width:767px){.gb-element-16f5ad3a{row-gap:40px}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-16f5ad3a"><!-- wp:generateblocks/media {"uniqueId":"5eca18dc","tagName":"img","styles":{"@media (max-width:1024px)":{"height":"150px"},"@media (max-width:767px)":{"height":"230px"},"height":"200px","objectFit":"cover","borderTopRightRadius":"8px","borderBottomRightRadius":"8px","borderBottomLeftRadius":"8px","borderTopLeftRadius":"8px","width":"auto","maxWidth":"100%","display":"block"},"css":".gb-media-5eca18dc{display:block;height:200px;max-width:100%;object-fit:cover;width:auto;border-radius:8px}@media (max-width:1024px){.gb-media-5eca18dc{height:150px}}@media (max-width:767px){.gb-media-5eca18dc{height:230px}}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg","title":"scott-blake-x-ghf9LjrVg-unsplash"},"mediaId":231,"linkHtmlAttributes":[],"metadata":[]} --> <img class="gb-media-5eca18dc" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg" title="scott-blake-x-ghf9LjrVg-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/media {"uniqueId":"c56bfcad","tagName":"img","styles":{"@media (max-width:1024px)":{"height":"150px"},"@media (max-width:767px)":{"height":"230px"},"height":"200px","objectFit":"cover","borderTopRightRadius":"8px","borderBottomRightRadius":"8px","borderBottomLeftRadius":"8px","borderTopLeftRadius":"8px","width":"auto","maxWidth":"100%","display":"block"},"css":".gb-media-c56bfcad{display:block;height:200px;max-width:100%;object-fit:cover;width:auto;border-radius:8px}@media (max-width:1024px){.gb-media-c56bfcad{height:150px}}@media (max-width:767px){.gb-media-c56bfcad{height:230px}}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/christopher-burns-8KfCR12oeUM-unsplash-1.jpg","title":"christopher-burns-8KfCR12oeUM-unsplash"},"mediaId":232,"linkHtmlAttributes":[],"metadata":[]} --> <img class="gb-media-c56bfcad" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/christopher-burns-8KfCR12oeUM-unsplash-1.jpg" title="christopher-burns-8KfCR12oeUM-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/media {"uniqueId":"bfad4a67","tagName":"img","styles":{"@media (max-width:1024px)":{"height":"150px"},"@media (max-width:767px)":{"height":"230px"},"height":"200px","objectFit":"cover","borderTopRightRadius":"8px","borderBottomRightRadius":"8px","borderBottomLeftRadius":"8px","borderTopLeftRadius":"8px","width":"auto","maxWidth":"100%","display":"block"},"css":".gb-media-bfad4a67{display:block;height:200px;max-width:100%;object-fit:cover;width:auto;border-radius:8px}@media (max-width:1024px){.gb-media-bfad4a67{height:150px}}@media (max-width:767px){.gb-media-bfad4a67{height:230px}}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/c-dustin-91AQt9p4Mo8-unsplash-1.jpg","title":"c-dustin-91AQt9p4Mo8-unsplash"},"mediaId":233,"linkHtmlAttributes":[],"metadata":[]} --> <img class="gb-media-bfad4a67" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/c-dustin-91AQt9p4Mo8-unsplash-1.jpg" title="c-dustin-91AQt9p4Mo8-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/media {"uniqueId":"9a57e805","tagName":"img","styles":{"@media (max-width:1024px)":{"height":"150px"},"@media (max-width:767px)":{"height":"230px"},"height":"200px","objectFit":"cover","borderTopRightRadius":"8px","borderBottomRightRadius":"8px","borderBottomLeftRadius":"8px","borderTopLeftRadius":"8px","width":"auto","maxWidth":"100%","display":"block"},"css":".gb-media-9a57e805{display:block;height:200px;max-width:100%;object-fit:cover;width:auto;border-radius:8px}@media (max-width:1024px){.gb-media-9a57e805{height:150px}}@media (max-width:767px){.gb-media-9a57e805{height:230px}}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/daniel-mccullough-HtBlQdxfG9k-unsplash.jpg","title":"daniel-mccullough-HtBlQdxfG9k-unsplash"},"mediaId":234,"linkHtmlAttributes":[],"metadata":[]} --> <img class="gb-media-9a57e805" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/daniel-mccullough-HtBlQdxfG9k-unsplash.jpg" title="daniel-mccullough-HtBlQdxfG9k-unsplash"/> <!-- /wp:generateblocks/media --></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --></section> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"e44f6c36","tagName":"section","styles":{"@media (max-width:767px)":{"paddingTop":"60px","paddingRight":"30px","paddingBottom":"60px","paddingLeft":"30px"},"maxWidth":"var(\u002d\u002dgb-container-width)","paddingTop":"100px","paddingRight":"40px","paddingBottom":"100px","paddingLeft":"40px","marginRight":"auto","marginLeft":"auto"},"css":".gb-element-e44f6c36{margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);padding:100px 40px}@media (max-width:767px){.gb-element-e44f6c36{padding:60px 30px}}","htmlAttributes":[],"metadata":[]} --> <section class="gb-element-e44f6c36"><!-- wp:generateblocks/text {"uniqueId":"932455e0","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"fontSize":"16px","textAlign":"center","color":"var(\u002d\u002daccent)"},"css":".gb-text-932455e0{color:var(\u002d\u002daccent);font-size:16px;text-align:center}@media (max-width:767px){.gb-text-932455e0{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text gb-text-932455e0">Our services</h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"8e27b87f","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"24px"},"fontSize":"29px","textTransform":"capitalize","textAlign":"center","marginBottom":"60px"},"css":".gb-text-8e27b87f{font-size:29px;margin-bottom:60px;text-align:center;text-transform:capitalize}@media (max-width:767px){.gb-text-8e27b87f{font-size:24px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text gb-text-8e27b87f">What we offer</h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/element {"uniqueId":"8ca4071c","tagName":"div","styles":{"display":"grid","gridTemplateColumns":"repeat(3, minmax(0, 1fr))","columnGap":"40px","rowGap":"100px","@media (max-width:1024px)":{"gridTemplateColumns":"repeat(2, minmax(0, 1fr))"},"@media (max-width:767px)":{"gridTemplateColumns":"1fr"},"height":"100%"},"css":".gb-element-8ca4071c{column-gap:40px;display:grid;grid-template-columns:repeat(3,minmax(0,1fr));height:100%;row-gap:100px}@media (max-width:1024px){.gb-element-8ca4071c{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (max-width:767px){.gb-element-8ca4071c{grid-template-columns:1fr}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-8ca4071c"><!-- wp:generateblocks/element {"uniqueId":"92d33ae2","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"135a666e","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative","display":"block"},"css":".gb-element-135a666e{display:block;position:relative}@media (max-width:767px){.gb-element-135a666e{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-135a666e"><!-- wp:generateblocks/media {"uniqueId":"271e6360","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-271e6360{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/sean-pollock-PhYq704ffdA-unsplash.jpg","title":"sean-pollock-PhYq704ffdA-unsplash"},"mediaId":361} --> <img class="gb-media-271e6360" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/sean-pollock-PhYq704ffdA-unsplash.jpg" title="sean-pollock-PhYq704ffdA-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"ca665538","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-ca665538{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-ca665538 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-ca665538"><span class="gb-shape"><svg viewBox="0 0 213 213" xmlns="http://www.w3.org/2000/svg"><path d="M201.333 181.734V61.374c0-7.185-5.723-13.374-12.907-13.374h-47.093V27.248c0-7.185-5.796-13.248-12.98-13.248h-3.02v-2.713c0-6.082-5.058-11.287-11.14-11.287H39.067c-6.082 0-11.733 5.205-11.733 11.287V14h-2.427c-7.185 0-13.573 6.063-13.573 13.248v154.486C5.334 183.775.396 189.846.396 197c0 8.822 7.449 16 16.271 16h180c8.822 0 15.939-7.178 15.939-16-.001-7.154-5.273-13.225-11.273-15.266zM94.333 196h-36v-33h36v33zm29-58h-94v-18h94v18zm0-41h-94V79h94v18zm0-41h-94V38h94v18zm61 82h-35v-18h35v18zm0-41h-35V79h35v18z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"b2181818","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-b2181818{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-b2181818{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-b2181818">Architecture & building</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"32f9b6c5","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-32f9b6c5{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-32f9b6c5:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-32f9b6c5 .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-32f9b6c5" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"2f001c6e","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"561ffaf7","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative"},"css":".gb-element-561ffaf7{position:relative}@media (max-width:767px){.gb-element-561ffaf7{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-561ffaf7"><!-- wp:generateblocks/media {"uniqueId":"55992480","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-55992480{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/nathan-waters-j7q-Z9DV3zw-unsplash.jpg","title":"nathan-waters-j7q-Z9DV3zw-unsplash"},"mediaId":241} --> <img class="gb-media-55992480" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/nathan-waters-j7q-Z9DV3zw-unsplash.jpg" title="nathan-waters-j7q-Z9DV3zw-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"fa969111","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-fa969111{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-fa969111 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-fa969111"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 479.334 479.334"><path d="M89.365 48.24H16.361C7.326 48.24 0 55.565 0 64.593v394.22c0 9.028 7.326 16.354 16.361 16.354h73.005c9.02 0 16.346-7.326 16.346-16.354V64.593c-.001-9.028-7.327-16.353-16.347-16.353zM176.974 167.631h261.518a16.353 16.353 0 0 0 15.117-10.094c2.519-6.112 1.135-13.15-3.545-17.824L319.296 8.954c-6.391-6.384-16.749-6.384-23.126 0L165.402 139.713a16.34 16.34 0 0 0-3.545 17.824 16.354 16.354 0 0 0 15.117 10.094zM214.814 407.157c16.905-34.271 52.102-57.91 92.912-57.91s76.005 23.639 92.896 57.91h22.535c9.036 0 16.362-7.326 16.362-16.354V273.877c0-9.028-7.326-16.353-16.362-16.353H192.293c-9.02 0-16.345 7.324-16.345 16.353v116.925c0 9.028 7.324 16.354 16.345 16.354h22.521zM462.971 189.847H152.478c-9.021 0-16.345 7.324-16.345 16.353v16.711c0 9.028 7.324 16.354 16.345 16.354h310.493c9.036 0 16.362-7.326 16.362-16.354V206.2c.001-9.028-7.325-16.353-16.362-16.353zM462.971 425.75H152.478c-9.021 0-16.345 7.324-16.345 16.353v16.711c0 9.028 7.324 16.354 16.345 16.354h310.493c9.036 0 16.362-7.326 16.362-16.354v-16.711c.001-9.029-7.325-16.353-16.362-16.353z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"31df4eaf","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-31df4eaf{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-31df4eaf{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-31df4eaf">Construction management</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"db30826c","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-db30826c{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-db30826c:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-db30826c .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-db30826c" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"b7d77f69","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"e9a032f9","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative"},"css":".gb-element-e9a032f9{position:relative}@media (max-width:767px){.gb-element-e9a032f9{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-e9a032f9"><!-- wp:generateblocks/media {"uniqueId":"1221a65a","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-1221a65a{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/danist-soh-8Gg2Ne_uTcM-unsplash_1.jpg","title":"danist-soh-8Gg2Ne_uTcM-unsplash_1"},"mediaId":405} --> <img class="gb-media-1221a65a" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/danist-soh-8Gg2Ne_uTcM-unsplash_1.jpg" title="danist-soh-8Gg2Ne_uTcM-unsplash_1"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"18ad3068","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-18ad3068{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-18ad3068 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-18ad3068"><span class="gb-shape"><svg viewBox="0 0 245 256" xmlns="http://www.w3.org/2000/svg"><path d="M94.338 47.137v2.452c0 15.611 12.654 28.265 28.265 28.265s28.265-12.654 28.265-28.265v-2.452h-56.53zm67.568-13.811v7.881H83.094v-7.881h5.517c1.058-13.06 9.469-24.039 21.088-28.794v16.972h4.926V2.942a34.226 34.226 0 0 1 15.76-.044v18.606h4.926V4.448c11.722 4.711 20.221 15.743 21.285 28.878h5.31zm74.7 100.71c-3.92-3.75-9.073-5.689-14.507-5.445-10.552.466-18.817 9.328-18.817 20.177v11.643h-9.852v-39.406c0-19.443-16.309-35.016-35.676-35.016h-7.659l-20.7 34.031-2.955-25.936 2.955-8.171h-13.792l2.955 8.171-2.955 25.936-20.688-34.032h-7.67c-19.443 0-35.676 15.649-35.676 35.016v39.406h-9.852v-11.65c0-10.849-8.265-19.712-18.816-20.177-5.43-.236-10.586 1.694-14.507 5.446-3.923 3.753-6.083 8.81-6.083 14.238v85.469h.008c-.15 5.308 1.776 10.327 5.445 14.169 3.755 3.931 8.815 6.096 14.25 6.096h200.971c5.435 0 10.496-2.165 14.25-6.097 3.668-3.841 5.594-8.858 5.446-14.164l.007-85.466c0-5.429-2.16-10.484-6.082-14.238zm-71.745-6.136a2.955 2.955 0 0 1 2.955 2.955v29.555h-5.911v-29.555a2.957 2.957 0 0 1 2.956-2.955zm-87.678 2.956a2.955 2.955 0 0 1 5.91 0v29.555h-5.911v-29.555zm-66.991 17.41c0-3.257 1.296-6.291 3.651-8.543 2.221-2.126 5.052-3.449 8.711-3.267 6.22.309 11.282 5.794 11.282 12.304v69.77c-3.648-2.751-8.099-4.129-12.748-3.916-4.058.187-7.821 1.641-10.896 3.969v-70.317zm221.344 94.194a11.72 11.72 0 0 1-8.551 3.659H22.014a11.718 11.718 0 0 1-8.551-3.659c-2.251-2.357-3.409-5.457-3.259-8.727.278-6.028 5.217-10.968 11.246-11.246 3.276-.146 6.37 1.006 8.727 3.259a11.72 11.72 0 0 1 3.659 8.551h7.881v-66.005h9.852v26.599c0 6.81 5.997 11.822 12.807 11.822s12.807-5.012 12.807-11.822v-26.599h90.634v26.599c0 6.81 5.997 12.807 12.807 12.807 6.81 0 12.807-5.997 12.807-12.807v-26.599h9.852v66.005h7.881c0-3.261 1.3-6.298 3.659-8.551 2.357-2.252 5.442-3.412 8.727-3.259 6.028.277 10.968 5.217 11.246 11.246.15 3.27-1.008 6.37-3.26 8.727zm3.271-23.876c-3.075-2.328-6.445-3.991-11.834-3.991-4.31 0-8.407 1.372-11.809 3.937v-69.762c0-6.51 5.061-12.03 11.282-12.304 3.261-.143 6.358 1.015 8.711 3.266a11.721 11.721 0 0 1 3.65 8.543v70.311z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"ef975624","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-ef975624{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-ef975624{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-ef975624">Plan estimations</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"e4085e8c","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-e4085e8c{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-e4085e8c:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-e4085e8c .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-e4085e8c" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"e873a692","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"ecd61e22","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative"},"css":".gb-element-ecd61e22{position:relative}@media (max-width:767px){.gb-element-ecd61e22{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-ecd61e22"><!-- wp:generateblocks/media {"uniqueId":"733ad2e5","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-733ad2e5{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/roberto-nickson-tleCJiDOri0-unsplash_1.jpg","title":"roberto-nickson-tleCJiDOri0-unsplash_1"},"mediaId":408} --> <img class="gb-media-733ad2e5" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/roberto-nickson-tleCJiDOri0-unsplash_1.jpg" title="roberto-nickson-tleCJiDOri0-unsplash_1"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"a333d424","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-a333d424{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-a333d424 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-a333d424"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 498.8 525"><path d="M113.8 481.3c0 24.1 19.6 43.8 43.8 43.8H455c24.1 0 43.8-19.6 43.8-43.8V43.8C498.8 19.6 479.1 0 455 0H157.5c-24.1 0-43.8 19.6-43.8 43.8v288.8h17.5V43.8c0-14.5 11.8-26.3 26.3-26.3H455c14.5 0 26.3 11.8 26.3 26.3v437.5c0 14.5-11.8 26.3-26.3 26.3H157.5c-14.5 0-26.3-11.8-26.3-26.3v-70h-17.5v70z"></path><path d="M148.8 446.3c0 4.8 3.9 8.8 8.8 8.8H455c4.8 0 8.8-3.9 8.8-8.8V43.8c0-4.8-3.9-8.8-8.8-8.8H157.5c-4.8 0-8.8 3.9-8.8 8.8v288.8h17.5v-280h280v385h-280v-26.3h-17.5v35zM262.5 472.5H350V490h-87.5v-17.5zM0 148.8v350C0 513.2 11.8 525 26.3 525s26.3-11.8 26.3-26.3V96.3c0-1.4-.3-2.7-.9-3.9l-17.5-35c-3-5.9-12.7-5.9-15.7 0L1 92.4c-.7 1.1-1 2.5-1 3.9v35h17.5v-33l8.8-17.5L35 98.3v347.9H17.5V148.7l-17.5.1zm35 315v35c0 4.8-3.9 8.8-8.8 8.8s-8.8-3.9-8.8-8.8v-35H35zM35 0h-8.8c-4.8 0-8.8 3.9-8.8 8.8v8.8H35V0zM141 393.8v-17.5h-9.7c-2 0-4-.2-5.9-.5l-2.9 17.3c2.9.5 5.8.7 8.8.7h9.7zM78.8 300h17.5v17.1H78.8V300zM78.8 60.5h17.5v17.1H78.8V60.5zM72.7 32.8c2.6 3.8 4.4 8 5.3 12.5l17.1-3.6c-1.4-6.7-4.1-13.1-8-18.8l-14.4 9.9zM78.8 231.6h17.5v17.1H78.8v-17.1zM78.8 129h17.5v17.1H78.8V129zM78.8 94.8h17.5v17.1H78.8V94.8zM78.8 265.8h17.5v17.1H78.8v-17.1zM78.8 197.4h17.5v17.1H78.8v-17.1zM78.8 163.2h17.5v17.1H78.8v-17.1zM72.6 8.7C66.9 4.8 60.5 2.3 53.7 1l-3.3 17.2c4.5.9 8.7 2.6 12.6 5.1l9.6-14.6z"></path><path d="M158.1 376.3h17.1v17.5h-17.1v-17.5zM96.3 334.2H78.8v7.1c0 4 .5 8 1.4 11.9l17-4c-.6-2.6-.9-5.3-.9-8v-7zM103.4 385.7l9.3-14.8c-3.9-2.4-7.2-5.6-9.9-9.3l-14.2 10.2c3.9 5.6 8.9 10.3 14.8 13.9zM428.8 113.8v-35c0-4.8-3.9-8.8-8.8-8.8h-35v17.5h26.3v26.3h17.5zM183.8 78.8v35h17.5V87.5h26.3V70h-35c-4.9 0-8.8 3.9-8.8 8.8zM227.5 122.5c-4.8 0-8.8 3.9-8.8 8.8v17.5H210c-4.8 0-8.8 3.9-8.8 8.8v61.3c0 4.8 3.9 8.8 8.8 8.8h192.5c4.8 0 8.8-3.9 8.8-8.8v-61.3c0-4.8-3.9-8.8-8.8-8.8h-8.8v-17.5c0-4.8-3.9-8.8-8.8-8.8H227.5zm8.8 87.5h-17.5v-43.8h17.5V210zm17.5-17.5h105V210h-105v-17.5zm140 17.5h-17.5v-43.8h17.5V210zm-26.3-61.2c-4.8 0-8.8 3.9-8.8 8.8V175h-105v-17.5c0-4.8-3.9-8.8-8.8-8.8h-8.8V140h140v8.8h-8.6zM411.3 306.3v-35c0-4.8-3.9-8.8-8.8-8.8H280c-4.8 0-8.8 3.9-8.8 8.8v35c0 4.8 3.9 8.8 8.8 8.8h40.1L300 335.2l12.4 12.4 28.8-28.8 28.8 28.8 12.4-12.4-20-20.2h40.1c4.8 0 8.8-3.9 8.8-8.7zm-17.5-8.8h-105V280h105v17.5z"></path><path d="M153.9 357.4c-.2 3.7 2 7.1 5.4 8.5l32.1 13.3 8.7 33.7c.9 3.6 4 6.2 7.7 6.5h.8c3.4 0 6.5-2 7.9-5l36.5-78.1c1.5-3.1.9-6.8-1.3-9.4s-5.9-3.6-9.2-2.6L160 349.4c-3.5 1.1-6 4.3-6.1 8zm74.8-10.8-17.8 38.1-3.7-14.3c-.7-2.7-2.6-4.9-5.1-5.9l-13.6-5.6 40.2-12.3z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"3835c66d","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-3835c66d{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-3835c66d{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-3835c66d">Interior design</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"4595f2a1","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-4595f2a1{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-4595f2a1:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-4595f2a1 .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-4595f2a1" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"4d0d0b86","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"b3d9ec35","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative"},"css":".gb-element-b3d9ec35{position:relative}@media (max-width:767px){.gb-element-b3d9ec35{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-b3d9ec35"><!-- wp:generateblocks/media {"uniqueId":"d0f70e3b","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-d0f70e3b{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg","title":"scott-blake-x-ghf9LjrVg-unsplash"},"mediaId":231} --> <img class="gb-media-d0f70e3b" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg" title="scott-blake-x-ghf9LjrVg-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"8988f876","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-8988f876{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-8988f876 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-8988f876"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 471.194 471.194"><path d="M435.332 293.684v-74.847c0-6.904-5.597-12.5-12.5-12.5h-16.197v-55.5c0-6.904-5.596-12.5-12.5-12.5s-12.5 5.596-12.5 12.5v55.5H330.45v-55.5c0-6.904-5.597-12.5-12.5-12.5h-73.884a12.5 12.5 0 0 0-11.878 8.606l-3.278 9.999L50.752 75.517a12.502 12.502 0 0 0-16.566 6.174l-19.3 42.24a12.5 12.5 0 0 0 4.581 15.691L33 148.375v92.147c-19.028 5.446-33 22.986-33 43.74 0 25.089 20.411 45.5 45.5 45.5S91 309.35 91 284.262c0-20.754-13.972-38.294-33-43.74v-75.977l146.683 94.872v34.268c-20.836 7.139-35.862 26.908-35.862 50.133 0 29.219 23.771 52.99 52.99 52.99h196.392c29.219 0 52.99-23.771 52.99-52.99.001-23.226-15.025-42.995-35.861-50.134zM66 284.262c0 11.304-9.196 20.5-20.5 20.5s-20.5-9.196-20.5-20.5 9.196-20.5 20.5-20.5 20.5 9.196 20.5 20.5zm251.949-52.925h92.382v59.49H229.683v-45.49H271.6c6.903 0 12.5-5.596 12.5-12.5v-69.5h21.349v55.5c0 6.904 5.597 12.5 12.5 12.5zm-58.849-68v57h-24.665l18.687-57h5.978zM51.729 103.451l169.343 77.397-15.767 48.095c-.101.307-.188.618-.265.931L42.114 124.496l9.615-21.045zm366.475 268.357H221.812c-15.434 0-27.99-12.556-27.99-27.99s12.556-27.99 27.99-27.99h196.392c15.434 0 27.99 12.556 27.99 27.99s-12.556 27.99-27.99 27.99z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"d422e932","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-d422e932{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-d422e932{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-d422e932">Reconstruction & dismantling</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"2c8cd44b","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-2c8cd44b{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-2c8cd44b:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-2c8cd44b .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-2c8cd44b" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"d4d9ae95","tagName":"div","styles":[],"htmlAttributes":[],"metadata":[]} --> <div><!-- wp:generateblocks/element {"uniqueId":"06914873","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"position":"relative"},"css":".gb-element-06914873{position:relative}@media (max-width:767px){.gb-element-06914873{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-06914873"><!-- wp:generateblocks/media {"uniqueId":"7b5285ee","tagName":"img","styles":{"height":"250px","maxWidth":"100%","objectFit":"cover","width":"100%","display":"block"},"css":".gb-media-7b5285ee{display:block;height:250px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg","title":"scott-blake-x-ghf9LjrVg-unsplash"},"mediaId":231} --> <img class="gb-media-7b5285ee" src="https://playground.alvind.com.my/wp-content/uploads/2021/12/scott-blake-x-ghf9LjrVg-unsplash-1.jpg" title="scott-blake-x-ghf9LjrVg-unsplash"/> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"38b31999","tagName":"h2","styles":{"display":"inline-flex","alignItems":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","backgroundColor":"var(\u002d\u002daccent)",".gb-shape svg":{"color":"var(\u002d\u002dbase-2)","fill":"currentColor","width":"0.8em","height":"0.8em"},"position":"absolute","top":"0px","left":"0px"},"css":".gb-text-38b31999{align-items:center;background-color:var(\u002d\u002daccent);display:inline-flex;left:0px;position:absolute;top:0px;padding:20px}.gb-text-38b31999 .gb-shape svg{color:var(\u002d\u002dbase-2);fill:currentColor;width:0.8em;height:0.8em}","htmlAttributes":[],"iconOnly":true,"metadata":[]} --> <h2 class="gb-text-38b31999"><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 329.209 329.209"><path d="M64.99 131.391c1.247 1.103 2.971 1.501 4.627 1.165 1.638-.325 3.063-1.459 3.806-2.966.278-.565 3.315-5.874 13.438-4.945 13.008 1.182 21.486 7.042 21.57 7.095.937.661 2.024.99 3.107.99a5.397 5.397 0 0 0 3.636-1.413l32.252-29.564a5.389 5.389 0 0 0 1.176-6.371l-13.521-27.034c14.063-23.806 42.312-25.709 50.853-25.709 1.122 0 1.784.037 2.246.053l6.719-.053a5.375 5.375 0 0 0 4.976-3.452 5.36 5.36 0 0 0-1.39-5.892c-14.122-12.926-31.69-19.481-52.237-19.481-40.966 0-83.381 27.113-91.982 45.397-10.177 21.626-22.998 34.644-23.132 34.778a5.398 5.398 0 0 0-1.565 3.968 5.389 5.389 0 0 0 1.825 3.864l33.596 29.57zM38.17 166.357a5.393 5.393 0 0 0 3.956 1.259 5.345 5.345 0 0 0 3.677-1.938l18.814-22.845a5.368 5.368 0 0 0-.586-7.443l-34.94-30.909c-1.065-.948-2.446-1.399-3.892-1.339a5.374 5.374 0 0 0-3.699 1.811L1.343 127.801a5.333 5.333 0 0 0-1.329 3.935 5.371 5.371 0 0 0 1.877 3.708l36.279 30.913zM327.973 264.453a5.403 5.403 0 0 0-1.213-1.753l-91.865-88.127-37.406-36.505 77.066-71.24 3.852 3.854a5.378 5.378 0 0 0 3.802 1.575c.072 0 .152 0 .226-.005a5.376 5.376 0 0 0 3.88-1.903l28.42-33.643a5.388 5.388 0 0 0-.73-7.657l-10.525-8.488a5.39 5.39 0 0 0-6.735-.016l-33.35 26.677a5.388 5.388 0 0 0-2.005 3.904 5.362 5.362 0 0 0 1.564 4.102l3.995 3.994-77.167 71.332-28.46-27.775a5.382 5.382 0 0 0-7.283-.205l-36.956 32.253a5.382 5.382 0 0 0-1.84 3.777 5.364 5.364 0 0 0 1.445 3.947l27.883 29.8-3.525 3.261-13.58-13.744c-1.971-2.005-5.187-2.128-7.32-.299L2.703 262.5a5.498 5.498 0 0 0-1.433 1.953c-3.926 9.098 1.703 23.469 14.003 35.765 9.352 9.359 20.553 15.177 29.231 15.177 2.981 0 5.633-.662 7.879-1.96.405-.229.78-.52 1.108-.85l108.375-108.289a5.378 5.378 0 0 0 .021-7.581l-13.294-13.449 3.312-3.061 123.715 132.26c.363.377.782.713 1.233.977 2.247 1.301 4.898 1.953 7.88 1.953 8.673 0 19.874-5.817 29.233-15.172 12.301-12.301 17.933-26.672 14.007-35.77zm-309.161 9.381c-.753 0-1.499-.32-2.031-.93a2.68 2.68 0 0 1 .275-3.789l98.642-85.451a2.687 2.687 0 0 1 3.79.274 2.681 2.681 0 0 1-.273 3.789l-98.644 85.449a2.672 2.672 0 0 1-1.759.658zm14.112 14.111a2.689 2.689 0 0 1-1.869-4.615l93.064-90.604a2.69 2.69 0 0 1 3.798.052 2.69 2.69 0 0 1-.052 3.8L34.8 287.182a2.67 2.67 0 0 1-1.876.763zm108.067-82.668-92.054 92.625a2.651 2.651 0 0 1-1.903.792c-.688 0-1.37-.263-1.898-.782a2.695 2.695 0 0 1-.01-3.8l92.054-92.626a2.688 2.688 0 1 1 3.811 3.791z"></path></svg></span></h2> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"5edcffa4","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","textAlign":"center","paddingTop":"20px","paddingRight":"20px","paddingBottom":"20px","paddingLeft":"20px","marginBottom":"0px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-5edcffa4{background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);font-size:18px;margin-bottom:0px;text-align:center;padding:20px}@media (max-width:767px){.gb-text-5edcffa4{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-5edcffa4">Repair & maintenance</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"8249b1ad","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"flex","alignItems":"center","justifyContent":"center","maxWidth":"250px","fontWeight":"600","textTransform":"uppercase","textAlign":"center","paddingTop":"16px","paddingRight":"16px","paddingBottom":"16px","paddingLeft":"16px","marginTop":"20px","marginRight":"auto","marginLeft":"auto","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-4)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-4)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-4)","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","fontSize":"13px","columnGap":"1em"},"css":".gb-text-8249b1ad{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:flex;font-size:13px;font-weight:600;justify-content:center;margin-left:auto;margin-right:auto;margin-top:20px;max-width:250px;text-align:center;text-decoration:none;text-transform:uppercase;border-right:1px solid var(\u002d\u002dcontrast-4);border-bottom:1px solid var(\u002d\u002dcontrast-4);border-left:1px solid var(\u002d\u002dcontrast-4);padding:16px}.gb-text-8249b1ad:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-8249b1ad .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-8249b1ad" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --></section> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"9b56ca5b","tagName":"section","styles":{"@media (max-width:1024px)":{"flexDirection":"column"},"@media (max-width:767px)":{"paddingTop":"60px","paddingRight":"30px","paddingBottom":"60px","paddingLeft":"30px"},"display":"flex","maxWidth":"var(\u002d\u002dgb-container-width)","paddingTop":"100px","paddingRight":"40px","paddingBottom":"100px","paddingLeft":"40px","marginRight":"auto","marginLeft":"auto"},"css":".gb-element-9b56ca5b{display:flex;margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);padding:100px 40px}@media (max-width:1024px){.gb-element-9b56ca5b{flex-direction:column}}@media (max-width:767px){.gb-element-9b56ca5b{padding:60px 30px}}","htmlAttributes":[],"metadata":[]} --> <section class="gb-element-9b56ca5b"><!-- wp:generateblocks/element {"uniqueId":"3c637c58","tagName":"div","styles":{"@media (max-width:1024px)":{"width":"100%","minHeight":"400px"},"@media (max-width:767px)":{"width":"100%","minHeight":"500px"},"backgroundImage":"url(https://playground.alvind.com.my/wp-content/uploads/2021/12/nathan-waters-j7q-Z9DV3zw-unsplash.jpg)","backgroundRepeat":"no-repeat","backgroundSize":"cover","backgroundPosition":"center center","width":"50%","position":"relative"},"css":".gb-element-3c637c58{background-image:url(https://playground.alvind.com.my/wp-content/uploads/2021/12/nathan-waters-j7q-Z9DV3zw-unsplash.jpg);background-position:center center;background-repeat:no-repeat;background-size:cover;position:relative;width:50%}@media (max-width:1024px){.gb-element-3c637c58{min-height:400px;width:100%}}@media (max-width:767px){.gb-element-3c637c58{min-height:500px;width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-3c637c58"><!-- wp:generateblocks/element {"uniqueId":"9655c607","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%","paddingTop":"30px","paddingRight":"30px","paddingBottom":"30px","paddingLeft":"30px","borderRightWidth":"1px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dcontrast-5)","borderBottomWidth":"1px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dcontrast-5)","borderLeftWidth":"1px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dcontrast-5)"},"backgroundColor":"var(\u002d\u002dbase-2)","flexDirection":"column","justifyContent":"flex-end","width":"50%","paddingTop":"30px","paddingRight":"30px","paddingBottom":"30px","paddingLeft":"30px","position":"absolute","bottom":"0px","left":"0px"},"css":".gb-element-9655c607{background-color:var(\u002d\u002dbase-2);bottom:0px;flex-direction:column;justify-content:flex-end;left:0px;position:absolute;width:50%;padding:30px}@media (max-width:767px){.gb-element-9655c607{width:100%;border-right:1px solid var(\u002d\u002dcontrast-5);border-bottom:1px solid var(\u002d\u002dcontrast-5);border-left:1px solid var(\u002d\u002dcontrast-5);padding:30px}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-9655c607"><!-- wp:generateblocks/text {"uniqueId":"98d7e92b","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px"},"css":".gb-text-98d7e92b{font-size:18px}@media (max-width:767px){.gb-text-98d7e92b{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text gb-text-98d7e92b">A leading player in the industry</h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"9de23a67","tagName":"p","styles":[],"htmlAttributes":[],"metadata":[]} --> <p class="gb-text">Quisque vitae velit in ex laoreet egestas ultricies et lorem.</p> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"a1c60344","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"color":"var(\u002d\u002dcontrast-3)"},"display":"inline-flex","alignItems":"center","fontWeight":"600","textTransform":"uppercase","textAlign":"center","color":"var(\u002d\u002daccent)",".gb-shape svg":{"width":"1em","height":"1em","fill":"currentColor"},"textDecoration":"none","columnGap":"1em","fontSize":"13px"},"css":".gb-text-a1c60344{align-items:center;color:var(\u002d\u002daccent);column-gap:1em;display:inline-flex;font-size:13px;font-weight:600;text-align:center;text-decoration:none;text-transform:uppercase}.gb-text-a1c60344:is(:hover,:focus){color:var(\u002d\u002dcontrast-3)}.gb-text-a1c60344 .gb-shape svg{width:1em;height:1em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-a1c60344" href="#"><span class="gb-text">Learn more</span><span class="gb-shape"><svg viewBox="0 0 44.952 44.952" xmlns="http://www.w3.org/2000/svg"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"449685e8","tagName":"div","styles":{"@media (max-width:1024px)":{"width":"100%","paddingTop":"60px","paddingRight":"60px","paddingBottom":"60px","paddingLeft":"60px"},"@media (max-width:767px)":{"width":"100%","paddingTop":"40px","paddingRight":"40px","paddingBottom":"40px","paddingLeft":"40px"},"backgroundColor":"var(\u002d\u002daccent)","width":"50%","height":"100%","paddingTop":"80px","paddingRight":"80px","paddingBottom":"80px","paddingLeft":"80px"},"css":".gb-element-449685e8{background-color:var(\u002d\u002daccent);height:100%;width:50%;padding:80px}@media (max-width:1024px){.gb-element-449685e8{width:100%;padding:60px}}@media (max-width:767px){.gb-element-449685e8{width:100%;padding:40px}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-449685e8"><!-- wp:generateblocks/text {"uniqueId":"992b13ca","tagName":"h3","styles":{"textTransform":"capitalize","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-992b13ca{color:var(\u002d\u002dbase-2);text-transform:capitalize}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-992b13ca">Best company ever & best service ever</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"68635565","tagName":"p","styles":{"fontSize":"14px","fontWeight":"500","marginBottom":"40px","color":"var(\u002d\u002dbase-2)"},"css":".gb-text-68635565{color:var(\u002d\u002dbase-2);font-size:14px;font-weight:500;margin-bottom:40px}","htmlAttributes":[],"metadata":[]} --> <p class="gb-text gb-text-68635565">Morbi efficitur mauris sit amet vestibulum vestibulum. Nullam ac nibh consectetur, ultrices lectus sed, maximus nibh.</p> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/element {"uniqueId":"e9eed161","tagName":"div","styles":{"@media (max-width:767px)":{"flexDirection":"column","rowGap":"20px"},"display":"flex","columnGap":"40px"},"css":".gb-element-e9eed161{column-gap:40px;display:flex}@media (max-width:767px){.gb-element-e9eed161{flex-direction:column;row-gap:20px}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-e9eed161"><!-- wp:generateblocks/element {"uniqueId":"c94976c0","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"width":"50%","height":"100%"},"css":".gb-element-c94976c0{height:100%;width:50%}@media (max-width:767px){.gb-element-c94976c0{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-c94976c0"><!-- wp:generateblocks/text {"uniqueId":"cd021b14","tagName":"h4","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","flexDirection":"column","fontSize":"16px","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"2em","height":"2em"},"rowGap":"1em"},"css":".gb-text-cd021b14{color:var(\u002d\u002dbase-2);display:flex;flex-direction:column;font-size:16px;row-gap:1em}.gb-text-cd021b14 .gb-shape svg{width:2em;height:2em}@media (max-width:767px){.gb-text-cd021b14{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h4 class="gb-text-cd021b14"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 576 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M259.3 17.8L194 150.2 47.9 171.5c-26.2 3.8-36.7 36.1-17.7 54.6l105.7 103-25 145.5c-4.5 26.3 23.2 46 46.4 33.7L288 439.6l130.7 68.7c23.2 12.2 50.9-7.4 46.4-33.7l-25-145.5 105.7-103c19-18.5 8.5-50.8-17.7-54.6L382 150.2 316.7 17.8c-11.7-23.6-45.6-23.9-57.4 0z"></path></svg></span><span class="gb-text">Best product line</span></h4> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/headline {"uniqueId":"241cf95e","element":"p","blockVersion":3,"typography":{"fontSize":"13px","fontWeight":"500"},"textColor":"var(\u002d\u002dbase-2)"} --> <p class="gb-headline gb-headline-241cf95e gb-headline-text">Donec lacinia neque lacus, vitae porttitor lacus rutrum et.</p> <!-- /wp:generateblocks/headline --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"d0d870da","tagName":"div","styles":{"@media (max-width:767px)":{"width":"100%"},"width":"50%","height":"100%"},"css":".gb-element-d0d870da{height:100%;width:50%}@media (max-width:767px){.gb-element-d0d870da{width:100%}}","htmlAttributes":[],"metadata":[]} --> <div class="gb-element-d0d870da"><!-- wp:generateblocks/text {"uniqueId":"2e9bb5ce","tagName":"h4","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"display":"flex","flexDirection":"column","fontSize":"16px","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"2em","height":"2em"},"rowGap":"1em"},"css":".gb-text-2e9bb5ce{color:var(\u002d\u002dbase-2);display:flex;flex-direction:column;font-size:16px;row-gap:1em}.gb-text-2e9bb5ce .gb-shape svg{width:2em;height:2em}@media (max-width:767px){.gb-text-2e9bb5ce{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h4 class="gb-text-2e9bb5ce"><span class="gb-shape"><svg aria-hidden="true" role="img" height="1em" width="1em" viewBox="0 0 384 512" xmlns="http://www.w3.org/2000/svg"><path fill="currentColor" d="M97.12 362.63c-8.69-8.69-4.16-6.24-25.12-11.85-9.51-2.55-17.87-7.45-25.43-13.32L1.2 448.7c-4.39 10.77 3.81 22.47 15.43 22.03l52.69-2.01L105.56 507c8 8.44 22.04 5.81 26.43-4.96l52.05-127.62c-10.84 6.04-22.87 9.58-35.31 9.58-19.5 0-37.82-7.59-51.61-21.37zM382.8 448.7l-45.37-111.24c-7.56 5.88-15.92 10.77-25.43 13.32-21.07 5.64-16.45 3.18-25.12 11.85-13.79 13.78-32.12 21.37-51.62 21.37-12.44 0-24.47-3.55-35.31-9.58L252 502.04c4.39 10.77 18.44 13.4 26.43 4.96l36.25-38.28 52.69 2.01c11.62.44 19.82-11.27 15.43-22.03zM263 340c15.28-15.55 17.03-14.21 38.79-20.14 13.89-3.79 24.75-14.84 28.47-28.98 7.48-28.4 5.54-24.97 25.95-45.75 10.17-10.35 14.14-25.44 10.42-39.58-7.47-28.38-7.48-24.42 0-52.83 3.72-14.14-.25-29.23-10.42-39.58-20.41-20.78-18.47-17.36-25.95-45.75-3.72-14.14-14.58-25.19-28.47-28.98-27.88-7.61-24.52-5.62-44.95-26.41-10.17-10.35-25-14.4-38.89-10.61-27.87 7.6-23.98 7.61-51.9 0-13.89-3.79-28.72.25-38.89 10.61-20.41 20.78-17.05 18.8-44.94 26.41-13.89 3.79-24.75 14.84-28.47 28.98-7.47 28.39-5.54 24.97-25.95 45.75-10.17 10.35-14.15 25.44-10.42 39.58 7.47 28.36 7.48 24.4 0 52.82-3.72 14.14.25 29.23 10.42 39.59 20.41 20.78 18.47 17.35 25.95 45.75 3.72 14.14 14.58 25.19 28.47 28.98C104.6 325.96 106.27 325 121 340c13.23 13.47 33.84 15.88 49.74 5.82a39.676 39.676 0 0 1 42.53 0c15.89 10.06 36.5 7.65 49.73-5.82zM97.66 175.96c0-53.03 42.24-96.02 94.34-96.02s94.34 42.99 94.34 96.02-42.24 96.02-94.34 96.02-94.34-42.99-94.34-96.02z"></path></svg></span><span class="gb-text">Award-winning projects</span></h4> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/headline {"uniqueId":"c332632b","element":"p","blockVersion":3,"typography":{"fontSize":"13px","fontWeight":"500"},"textColor":"var(\u002d\u002dbase-2)"} --> <p class="gb-headline gb-headline-c332632b gb-headline-text">Donec lacinia neque lacus, vitae porttitor lacus rutrum et.</p> <!-- /wp:generateblocks/headline --></div> <!-- /wp:generateblocks/element --></div> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/text {"uniqueId":"3ae3b34e","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)"},"display":"inline-flex","alignItems":"center","justifyContent":"center","fontWeight":"600","textTransform":"capitalize","textAlign":"center","paddingTop":"12px","paddingRight":"26px","paddingBottom":"12px","paddingLeft":"26px","marginTop":"20px","borderTopWidth":"2px","borderTopStyle":"solid","borderTopColor":"var(\u002d\u002dbase-2)","borderRightWidth":"2px","borderRightStyle":"solid","borderRightColor":"var(\u002d\u002dbase-2)","borderBottomWidth":"2px","borderBottomStyle":"solid","borderBottomColor":"var(\u002d\u002dbase-2)","borderLeftWidth":"2px","borderLeftStyle":"solid","borderLeftColor":"var(\u002d\u002dbase-2)","borderTopRightRadius":"3px","borderBottomRightRadius":"3px","borderBottomLeftRadius":"3px","borderTopLeftRadius":"3px","backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"0.9em","height":"0.9em","fill":"currentColor"},"textDecoration":"none","columnGap":"1em"},"css":".gb-text-3ae3b34e{align-items:center;background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-2);column-gap:1em;display:inline-flex;font-weight:600;justify-content:center;margin-top:20px;text-align:center;text-decoration:none;text-transform:capitalize;border:2px solid var(\u002d\u002dbase-2);border-radius:3px;padding:12px 26px}.gb-text-3ae3b34e:is(:hover,:focus){background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2)}.gb-text-3ae3b34e .gb-shape svg{width:0.9em;height:0.9em;fill:currentColor}","htmlAttributes":{"href":"https://sites.generatepress.com/construction/contacts/"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-3ae3b34e" href="https://sites.generatepress.com/construction/contacts/"><span class="gb-text">Request a quote</span><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 44.952 44.952"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></div> <!-- /wp:generateblocks/element --></section> <!-- /wp:generateblocks/element --> <!-- wp:generateblocks/element {"uniqueId":"f12b593c","tagName":"section","styles":{"@media (max-width:767px)":{"paddingTop":"40px","paddingRight":"30px","paddingLeft":"30px"},"maxWidth":"var(\u002d\u002dgb-container-width)","paddingTop":"100px","paddingRight":"40px","paddingBottom":"100px","paddingLeft":"40px","marginRight":"auto","marginLeft":"auto"},"css":".gb-element-f12b593c{margin-left:auto;margin-right:auto;max-width:var(\u002d\u002dgb-container-width);padding:100px 40px}@media (max-width:767px){.gb-element-f12b593c{padding-left:30px;padding-right:30px;padding-top:40px}}","htmlAttributes":[],"metadata":[]} --> <section class="gb-element-f12b593c"><!-- wp:generateblocks/text {"uniqueId":"a5e20a90","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"15px"},"fontSize":"16px","textAlign":"center","color":"var(\u002d\u002daccent)"},"css":".gb-text-a5e20a90{color:var(\u002d\u002daccent);font-size:16px;text-align:center}@media (max-width:767px){.gb-text-a5e20a90{font-size:15px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text gb-text-a5e20a90">Features projects</h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"d74570a7","tagName":"h2","styles":{"@media (max-width:767px)":{"fontSize":"24px"},"fontSize":"29px","textTransform":"capitalize","textAlign":"center","marginBottom":"60px"},"css":".gb-text-d74570a7{font-size:29px;margin-bottom:60px;text-align:center;text-transform:capitalize}@media (max-width:767px){.gb-text-d74570a7{font-size:24px}}","htmlAttributes":[],"metadata":[]} --> <h2 class="gb-text gb-text-d74570a7">Our latest projects</h2> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/query {"uniqueId":"6189f8f2","tagName":"div","query":{"post_type":["post"],"posts_per_page":"3"}} --> <div><!-- wp:generateblocks/looper {"uniqueId":"d708a70e","tagName":"div","styles":{"display":"flex","columnGap":"40px","rowGap":"80px","@media (max-width:1024px)":{"flexWrap":"wrap"},"justifyContent":"center"},"css":".gb-looper-d708a70e{column-gap:40px;display:flex;justify-content:center;row-gap:80px}@media (max-width:1024px){.gb-looper-d708a70e{flex-wrap:wrap}}"} --> <div class="gb-looper-d708a70e"><!-- wp:generateblocks/loop-item {"uniqueId":"e2963a8b","tagName":"article","styles":{"width":"100%","maxWidth":"400px","flexDirection":"column","display":"flex","justifyContent":"space-between","@media (max-width:767px)":{"maxWidth":"100%"}},"css":".gb-loop-item-e2963a8b{display:flex;flex-direction:column;justify-content:space-between;max-width:400px;width:100%}@media (max-width:767px){.gb-loop-item-e2963a8b{max-width:100%}}"} --> <article class="gb-loop-item gb-loop-item-e2963a8b"><!-- wp:generateblocks/media {"uniqueId":"dec17683","tagName":"img","styles":{"height":"250px","objectFit":"cover","marginBottom":"10px","width":"100%","maxWidth":"100%","display":"block"},"css":".gb-media-dec17683{display:block;height:250px;margin-bottom:10px;max-width:100%;object-fit:cover;width:100%}","htmlAttributes":{"src":"{{featured_image size:large|key:url}}"},"linkHtmlAttributes":{"href":"{{post_permalink}}"},"metadata":[]} --> <a href="{{post_permalink}}"><img class="gb-media-dec17683" src="{{featured_image size:large|key:url}}"/></a> <!-- /wp:generateblocks/media --> <!-- wp:generateblocks/text {"uniqueId":"8153b8b1","tagName":"h3","styles":{"@media (max-width:767px)":{"fontSize":"17px"},"fontSize":"18px","marginBottom":"14px","a":{"color":"var(\u002d\u002dcontrast-3)"},"a:hover":{"color":"var(\u002d\u002daccent)"}},"css":".gb-text-8153b8b1{font-size:18px;margin-bottom:14px}.gb-text-8153b8b1 a{color:var(\u002d\u002dcontrast-3)}.gb-text-8153b8b1 a:hover{color:var(\u002d\u002daccent)}@media (max-width:767px){.gb-text-8153b8b1{font-size:17px}}","htmlAttributes":[],"metadata":[]} --> <h3 class="gb-text gb-text-8153b8b1">{{post_title link:post}}</h3> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"3ff3c463","tagName":"div","styles":{"paddingBottom":"30px"},"css":".gb-text-3ff3c463{padding-bottom:30px}","htmlAttributes":[],"metadata":[]} --> <div class="gb-text gb-text-3ff3c463">{{post_excerpt length:15}}</div> <!-- /wp:generateblocks/text --> <!-- wp:generateblocks/text {"uniqueId":"b42f32e0","tagName":"a","styles":{"\u0026:is(:hover, :focus)":{"backgroundColor":"var(\u002d\u002daccent)","color":"var(\u002d\u002dbase-2)"},"display":"flex","flexDirection":"row","alignItems":"center","justifyContent":"center","fontWeight":"600","textTransform":"uppercase","paddingTop":"16px","paddingRight":"30px","paddingBottom":"16px","paddingLeft":"30px","marginTop":"auto","borderTopRightRadius":"3px","borderBottomRightRadius":"3px","borderBottomLeftRadius":"3px","borderTopLeftRadius":"3px","backgroundColor":"var(\u002d\u002dcontrast-3)","color":"var(\u002d\u002dbase-2)",".gb-shape svg":{"width":"0.9em","height":"0.9em","fill":"currentColor"},"textDecoration":"none","columnGap":"1em"},"css":".gb-text-b42f32e0{align-items:center;background-color:var(\u002d\u002dcontrast-3);color:var(\u002d\u002dbase-2);column-gap:1em;display:flex;flex-direction:row;font-weight:600;justify-content:center;margin-top:auto;text-decoration:none;text-transform:uppercase;border-radius:3px;padding:16px 30px}.gb-text-b42f32e0:is(:hover,:focus){background-color:var(\u002d\u002daccent);color:var(\u002d\u002dbase-2)}.gb-text-b42f32e0 .gb-shape svg{width:0.9em;height:0.9em;fill:currentColor}","htmlAttributes":{"href":"#"},"iconLocation":"after","metadata":[]} --> <a class="gb-text-b42f32e0" href="#"><span class="gb-text">View project</span><span class="gb-shape"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 44.952 44.952"><path d="M44.952 22.108c0-1.25-.478-2.424-1.362-3.308L30.627 5.831a2.5 2.5 0 0 0-3.536 0 2.511 2.511 0 0 0 0 3.546l10.574 10.57H2.484C1.102 19.948 0 21.081 0 22.464v.028c0 1.382 1.102 2.523 2.484 2.523h35.182L27.094 35.579a2.504 2.504 0 0 0 3.538 3.54l12.958-12.97a4.633 4.633 0 0 0 1.362-3.309v-.732z"></path></svg></span></a> <!-- /wp:generateblocks/text --></article> <!-- /wp:generateblocks/loop-item --></div> <!-- /wp:generateblocks/looper --></div> <!-- /wp:generateblocks/query --></section> <!-- /wp:generateblocks/element -->This will give you the Construction starter site’s homepage layout as a starting point.
ISTM2026
Thanks! Working on it…
No problem — let us know if you have any further questions!
