rabidfox76
I’ve read through the documentation at https://docs.generatepress.com/article/navigation-search-modal/ and through past support topics, and I still don’t understand how to add a search modal when using a navigation element.
- I checked the check box in Customizer > Layout > Primary Navigation.
- I made a block element and chose type Search Modal. It is applied to the whole site.
- The documentation says to add ‘ data-gpmodal-trigger=”gp-search” ‘ as a custom attribute, but I don’t see where to add a custom attribute.
- No modal shows up.
All I want is a magnifying glass at the right of my menu that triggers a search box to pop up. I was easily able to do this in GP 1 using the built-in Primary Navigation.
Also, it looks like I’m supposed to add a magnifying glass icon manually. But I don’t see any such icon among the built-in icons. Is everyone getting one with SVG?
I understand that I can set the settings for the modal in the Customizer, so I think once I have it appearing at all I’ll be able to make it look right.
You don’t need to create an Element for this. Here are the steps on how to do it:
https://generate.support/topic/add-search-to-new-navigation-block/#post-168140For the search icon, you can use this custom SVG:
<svg xmlns="http://www.w3.org/2000/svg" width="32" height="32" viewBox="0 0 256 256" fill="currentColor"><path d="M232.49 215.51 185 168a92.12 92.12 0 1 0-17 17l47.53 47.54a12 12 0 0 0 17-17ZM44 112a68 68 0 1 1 68 68 68.07 68.07 0 0 1-68-68Z"></path></svg>
