Adding add to cart button by using shortcode doesn’t work
    I’m using the [add_to_cart id=”myid″] shortcode, but it doesn’t show the button.
    How could I fix this?
    Thank you!
    1. make sure the ID number is correct.
    2. make sure the Shorcode is using straight quote marks " and not curly or slanted eg.
    [add_to_cart id="30419"]
  • Yes. It worked. Thank you so much, David!
  • Glad to hear that!
