How can I make fonts registered in a Block Theme (via Theme.json and/or the WordPress Font Manager in the site editor) appear in the list of fonts in Generate Blocks ‘typography’ settings? All I see is ‘system fonts’.
its not directly possible at this time, it is something we are looking into for a future update.
For now you would need to pass the values to GB using this filter:
add_filter( 'generateblocks_typography_font_family_list', function( $fonts ) { $fonts[] = [ 'label' => 'My custom fonts', 'options' => [ [ 'label' => 'My Font Label', 'value' => 'my_font_family_name', ], ], ]; return $fonts; } );
No worries, that works perfectly! A setting to pull them in from theme.json would be a great feature. I’ve hacked together a snippet to pull them in automatically (NB there is no error handling or sanitisation included here):
add_filter( 'generateblocks_typography_font_family_list', function ($fonts) { // Only run this in the admin/editor, not on the front end if (is_admin()) { // Get the path to the active theme's theme.json file $theme_json_path = get_template_directory() . '/theme.json'; if (file_exists($theme_json_path)) { // Read the theme.json file $theme_json_content = file_get_contents($theme_json_path); $theme_json = json_decode($theme_json_content, true); // Check if there are font families declared in theme.json if (isset($theme_json['settings']['typography']['fontFamilies'])) { $font_families = $theme_json['settings']['typography']['fontFamilies']; // Create an array to hold the font options $font_options = []; // Loop through the font families and add them to the font options foreach ($font_families as $font_family) { if (isset($font_family['name']) && isset($font_family['slug'])) { $font_options[] = [ 'label' => $font_family['name'], 'value' => 'var(--wp--preset--font-family--' . $font_family['slug'] . ')', ]; } } // Add the fonts to the GenerateBlocks font family list if (!empty($font_options)) { $fonts[] = [ 'label' => 'Theme Fonts', 'options' => $font_options, ]; } } } } return $fonts; } );
Is there a method for removing the ‘system fonts’ options btw?
Perhaps this ?
function remove_system_fonts_from_generateblocks( $font_families ) { foreach ( $font_families as $key => $font_category ) { if ( $font_category['label'] === __( 'System Fonts', 'generateblocks' ) ) { unset( $font_families[$key] ); } } return array_values($font_families); } add_filter( 'generateblocks_typography_font_family_list', 'remove_system_fonts_from_generateblocks' );
Thanks, this borks the site but I’ll debug now I know what the filters are!
Sorry about that. Did you resolve the issue ?
