Adding leading text to Dynamic Tag output?
  • Use case: my custom field/meta key is location_phone_number holding data in the format of 123-456-7890.
    I’m using Dynamic Tags to display this and create a clickable link, but I need to prepend “tel:1” to the link output so it’s linked as href="tel:11234567890".
    Modifying the Dynamic Tag hasn’t worked so far, but I could just have the syntax wrong.
    {{post_meta key:location_phone_number|link:post_meta,location_phone_number}}
    Try to use the button block instead of text.
    and you can set dynamic content and dynamic links separately, and set the link destination to tel:{{post_meta key:location_phone_number}} like this:
    https://app.screencast.com/519ZZ7krO2izd
  • That did the trick – thanks!
  • No Problem 🙂
