themoneyskim
I have the GeneratePress Pro theme and Generateblocks Pro yet I do not have the pattern library when editing pages. How do I go about doing this? I already added the license key and re-downloaded the plugin.
Thanks,
Ella -
Hi Ella,
That’s strange. Just to confirm, you do not see the Pattern Library block in the block library as seen here?
https://docs.generateblocks.com/article/adding-generateblocks-in-the-block-editor/If so, can you confirm that GenerarateBlocks pro is indeed activated?
themoneyskim
That is correct the pattern library block is missing. And I have the Generateblocks Pro – Personal. I also did activate the key and it says activated on my site and my Generateblocks account.
themoneyskim
I forgot to mention that I also tried to do the copy-and-paste method from the Generateblocks site but it would not let me paste it into my site. I can copy, and it says copied, but when I go to paste, there is no option to even paste like it did not even paste anything.
Anonymous
Check your settings. You might have it disabled:
themoneyskim
I have that enabled as well. I already tried to turn them off and back on and did the sync remote patterns. I even deactivated the whole plugin and reinstalled it. Not seems to be working.
Hmm haven’t seen other reports on this and am unable to replicate it on my install.
Are you able to start a staging site (with all plugins disabled except for GB and GB Pro) and provide the backend access for us to take a look?
You can add the credentials in the private URL field.
themoneyskim
ok I just created and sent the credentials.
I see the site link and password but can you please provide the username as well?
Thanks 🙂
themoneyskim
I added it in the privacy. I will only leave the site up for another day then I will delete it
themoneyskim
I haven’t heard back in two days so I am going to go ahead and delete the started site and ask for a refund for the Generateblocks.
Sorry about that! We’ve been having issues with reply notifications internally.
Can you please keep the staging site for us to take a look?
Thank you.
themoneyskim
yeah, I can do it for another day because the staging site is messing with my other stuff.
can you confirm the login? As i cannot access the site with the ones provided.
themoneyskim
I updated the information in the private form.
The password and username did not work in the popup box:
https://www.screencast.com/t/6GpAhspHXCan you open the provided link in an incognito tab and make sure everything works properly first?
Thanks.
