ksen8
I’m having an issue with an element that I added to my page from the Pattern Library. It’s a container that has a background image and a text overlay. This background image is also darker than normal so I’m guessing there is some other black-colored overlay with a low opacity that allows the image behind it to be shown.
The problem is that I’m trying to add an optin form into this container, but when I add it it is automatically behind this dark colored overlay, so it appears to be shaded.
I know that there is a way to bring it to the front because the text overlay is in the front, but I just don’t know how.
Any help?
Here’s an image of what I mean:https://ibb.co/j64R0PW
Can you link us to the page in question?
You can use the private information field.
https://docs.generatepress.com/article/using-the-premium-support-forum/#private-informationLet me know 🙂
Yep. I’ve added some private info.
How is that form added? Is it a block?
ksen8
Yes. It’s a container from GenerateBlocks. It was from the GenerateBlocks pattern library so it was already premade with the shadow feature when I put it there but then I customized it some.
May I know how the opt-in form is being added? If it’s via code, can you provide the code here? Please remove any sensitive identifiers like ID of the form.
ksen8
Yes, it’s added via this code:
<getresponse-form form-id=”15ee6db7-6b7a-42dc-a8ae” e=”1″></getresponse-form>*I removed some of the form-id so it’s not exact.
place the form inside a GB Container Block.
Then set that Container Blocks Layout > Z-Index to 1 -
ksen8
Worked like a charm. Thank you!
ksen8
Also, do you have any idea how the shadow overlay was added to the GB Container Block?
If you select the parent Container Block – the one with the image and overlay
In the block settings > Bacground there is a Gradient that has been set as a Pseudo Element. Its that gradient that adds the overlay. -
ksen8
Thank you for this!
You’re welcome
