Additional condition in the elements
  • I saw in the documentation that you have an additional code to create a custom condition, but it seems that that condition works with a defined ID. I would like to create an option that appears in the elements edit menu Location to display or delete the same in the original plugin, without depending on putting ID. I need to create a page language condition to display different templates according to language.
    unfortunately that is not possible. The code fro the display rules logic is super complex and this no hooks in its code to change that behaviour.
  • It is a suggestion to have the option to add the URL in which that element will be activated, I think it is very much needed. So I could use the language subdirectory.
  • You should be able to use the PHP code to write your condition based on language.
  • I can create shortcodes to display content only in one language, but then it will get complicated would I have two templates being read?
  • Not sure what you mean, you can create 2 elements, and use PHP to disable/enable them based on language.
  • How would I do that?
  • The doc is here:
    https://docs.generatepress.com/article/generate_element_display/
    And to check language, the condition would be something like this:
    add_filter( 'generate_element_display', function( $display, $element_id ) {
        $locale = get_locale();
        if ( 100 === $element_id && $locale === 'en_US' ) {
            $display = true;
        if ( 200 === $element_id && $locale === 'fr_FR' ) {
            $display = true;
        return $display;
    }, 10, 2 );
  • Thank you, it worked perfectly, I used the first condition to activate and the second to delete.
  • Nice 🙂
