Additional text with dynamic (GB) Heading block
  • I have an archive category template where I want the page H1 header to be the category name plus some additional text e.g. Board Member – Member Name
    Board Member is fixed text, Member Name is GenerateBlocks Headline block set to dynamically get the category title which is the member name.
    If I set 2 blocks as inlineblock side by side, that looks OK, but its actually two H1 tags – really bad.
    Is there a way to merge these together into one H1 tag, or insert dynamic text with no tags at all into a string in the middle of a tag.
    LenW
    you would need to use some PHP to filter either the blocks content or simply filter the get_the_archive_title to alter the text string.
    For example:
    function prefix_category_archive_title($title) {
        if (is_category()) {
            $title = 'Board Member – ' . single_cat_title('', false);
        return $title;
    add_filter('get_the_archive_title', 'prefix_category_archive_title');
    This will add that text before the Category Archive title.
  • David, thanks, this isnt working, although it looks as though it should.
  • Try this PHP snippet instead:
        return $title;
    add_filter('get_the_archive_title', 'prefix_category_archive_title', 20);
