Hello, Im trying to move the upper AddToAny location after the “Created By: Webmaster”
before the icons, i want to add text: Share Now:
Do those Share Buttons have a
Shortcode
to make it appear?If it does, you can create a Block Element – Post Meta Template and add a Shortcode Block for the Share Buttons.
Reference: https://docs.generatepress.com/article/block-element-post-meta-template/
EDIT:
I saw the youtube guide, When I go to create new block element i dont have the “Block Element” to choose.
in the plugin itself you just select where you want it to appear and it just appear there.
just found the shortcode: [addtoany]
im trying to follow your links to make it work.
Alright. Let us know how it goes.
I saw the youtube guide, When I go to create new block element i dont have the “Block Element” to choose “Post Meta Template”
FYI: I Disabled gutenberg, idk if its the reason.
You’re correct.
You need to use the default WordPress Block Editor to use the Block Element feature of GP Premium.
In any case, can you try adding a filter like this as an alternative?:
add_filter( 'generate_post_author_output', function( $output ) { return do_shortcode('[addtoany]') . ' ' . '<span class="coauthor"> and <a href="' . $coauthor_link . '">' . $coauthor . '</a></span>'; } );
gigasb
Your support already helped with the next code snippet:
add_filter( 'generate_post_date_output', function( $output, $time_string ) { $time_string = '<time class="entry-date published" datetime="%1$s" itemprop="datePublished"><strong>נוצר בתאריך:</strong> %2$s</time>'; if ( get_the_date() !== get_the_modified_date() ) { $time_string = '<time class="entry-date published" datetime="%1$s" itemprop="datePublished"><strong>נוצר בתאריך:</strong> %2$s, </time><time class="entry-date updated-date" datetime="%3$s" itemprop="dateModified"><strong>עודכן בתאריך:</strong> %4$s</time>'; } $time_string = sprintf( $time_string, esc_attr( get_the_date( 'c' ) ), esc_html( get_the_date() ), esc_attr( get_the_modified_date( 'c' ) ), esc_html( get_the_modified_date() ) ); return sprintf( '<span class="posted-on">%s</span> ', $time_string ); }, 10, 2 );
so I guess both codes, need to be combined now, can you please help me with that?
the two codes should not need combining.
Have you tried added Fernandos code ? -
gigasb
its not working:
i like the codes u gave me for updated and created article date, i would like to keep it, only add the shortcode.
I replaced the code to the last one mentioned since its not good (until u reply) -
The code that Fernando provided can you change that to:
add_filter( 'generate_post_author_output', function( $output ) { return $output . do_shortcode('[addtoany]'); } );
gigasb
The result is:
I want to keep the Created on & Updated on titles (with the bold code)
if you will see the code you guys gave me last time, i just want to add the [addtoany] code after the Created By: Webmaster, and to keep it inline.There is a way to add the code on the code i pasted earlier ?
I am not seeing any change ? Is the last code i provided still on the site ?
gigasb
yes, the last one is active, i cleared css maybe refresh
Try adding this CSS now;
.single .entry-meta { display: flex; column-gap: 10px }
gigasb
Ok you can check the post now, its inline, I Enabled the last code & the new code (u can refresh the post)
Last problem I have, is that on mobile its not looks good, I need to make a <br> to the AddToAny code, ONLY if the user using a MOBILE phone
Try adding this CSS as well:
@media (max-width: 768px){ .single .entry-meta { flex-wrap: wrap; } }
