BeetsandBytes
Hello. I am wanting to change the website header elements to match the shared image below.
The layout would be logo > social media icons widget > site title > navbar buttons.I am wondering the best way to do this? I could potentially write everything up with html/css but perhaps I can just accomplish this flow of header elements by adjusting the generatepress settings?
Thank you,
Is your current header layout using custom CSS? Also, can you share what settings you currently have under Customize > Layout > Header?
BeetsandBytes
Hi Alvind,
Yes there is some CSS but I assume it would need to change to match the layout I wanted. I pasted that below.
And here is a link to those layout header settings: https://imgur.com/a/xdaV87S
Thanks for any help!
@media(min-width: 769px) {
.inside-header>.site-branding,
.inside-header>.navigation-branding,
.inside-header>.site-logo,
.site-branding-container,
#site-navigation .navigation-branding .site-logo,
#sticky-navigation .navigation-branding {
position: absolute;
left: 50%;
transform: translateX(-50%);
z-index: 1000;
}#site-navigation {
margin-left: unset !important;
display: flex;
}.site-header .main-navigation:not(#sticky-navigation) .inside-navigation {
margin: unset;
}#site-navigation,
#primary-menu,
.main-navigation .inside-navigation {
flex: 1;
}/* Change nth-child(#) to first item to right */
.main-navigation ul li:nth-child(3) {
margin-left: auto;
}.inside-header {
padding-top: 50px;}
.site-header .header-image {
margin-top: 100px;
}.site-header {
border-image: linear-gradient(#ffffff, #2a5d1b) 80;
border-bottom-style: solid;
border-bottom-width: 12px;
background-image: linear-gradient(#c83a85 20%,#ffffff 99%);
}@media (min-width:769px) {
.main-navigation .main-nav ul li.nav-button a {
background-color: rgba(198, 94, 148, 0.28)above;
border: 2px solid rgba(255, 255, 255, 0.78);
color: #ffffff;
border-radius: 10px;
line-height: 35px; /*this number will likely need to be adjusted*/
}#menu-item-38 {
display: none;
}#menu-item-67 {
display: none;
}#menu-item-35 {
padding-right: 15px;
}#menu-item-66 {
padding-left: 15px;
}.lsi-social-icons li a {
background: rgba(255, 255, 255, 0) !important;
}.lsi-social-icons li a:hover {
Can you remove all the CSS that is related to navigation or header except the ones below for border?
.site-header { border-image: linear-gradient(#ffffff, #2a5d1b) 80; border-bottom-style: solid; border-bottom-width: 12px; background-image: linear-gradient(#c83a85 20%,#ffffff 99%); } @media (min-width:769px) { .main-navigation .main-nav ul li.nav-button a { background-color: rgba(198, 94, 148, 0.28)above; border: 2px solid rgba(255, 255, 255, 0.78); color: #ffffff; border-radius: 10px; line-height: 35px; /*this number will likely need to be adjusted*/ } }
BeetsandBytes
Hello Ying, I have removed all the CSS except those snippets.
Thank you.
Now add this CSS:
@media(min-width: 769px) { .site-logo { order: -20; margin-bottom: -80px; z-index: 100; } nav#site-navigation { margin-left: auto; margin-right: 0 !important; } .header-widget { padding-left: 40px; } }
BeetsandBytes
Thank you Ying. What would be the best way to arrange the text widget I have on the header so that it doesn’t appear below the social icons, I wanted it on the right side instead?
Change the CSS to this:
@media(min-width: 769px) { .site-logo { order: -20; margin-bottom: -80px; z-index: 100; } nav#site-navigation { margin-left: auto; margin-right: 0 !important; } .header-widget { padding-left: 40px; display: flex; align-items: center; } }
