Adjusting Image Height in GP Editor Gallery Block
    I’ve created a gallery using the GP Editor’s gallery block. Is it possible to set all the images in the gallery to have the same height? If so, how can I achieve this?
    Thank you!
    GB doesn’t have a Gallery block, so it might be the core block or a gallery block from another plugin. You should check which one you’re using and refer to their documentation.
    Generally, if the original images have the same height, they should display with the same height in the gallery as well.
