Adjusting line spacing in footer
    I’m using part of one of the included templates, and modified the footer slightly. When I try to add additional lines of text to the columns, any additional line seems to have different line spacing. IE, the next line is closer together to the one above it, than the others are. Here are a few screenshots;
    https://prnt.sc/te8-7Ha4Y8n8
    I can also take that line item and shift it up and down through the column, and it also keeps the “close” spacing. See next screenshot; https://prnt.sc/jFNhdDOJIzST
    Where and how do I adjust the line spacing for those columns?
    to add space “after” the headline, select it and in Spacing > Margin add 10px of Bottom Margin.
    The Site designer would have set the last headlines margin bottom to 0 to remove unnecessary space.
