I’m planning how to build my client site at the moment – I want to add a load more button to a Loop-Block (either GB Query Loop or WordPress core query loop), I know GenerateBlocks doesn’t offer this at the moment, is my best bet to use the Ajax Load More plugin for it? Is GeneratePress compatible with it?Thanks!
Tina -
if you displaying posts in the GP archives / blog then you can activate Load More in the Blog settings:
https://docs.generatepress.com/article/blog-content-layout/
You can redesign the theme templates using a Block Element Content Template, and the Load more will still work:
https://docs.generatepress.com/article/block-element-content-template/
Hi David,
I have to display the posts at the bottom of single posts though… :/ Otherwise that would be a good solution
Best,
Tina -
Are you wanting to load the next single post ?
Yes, the next single post(s – ideally more than one)
Hi Tina,
To clarify, this Load More button, would be an AJAX Load More button on Single Post pages, not the Blog page?
If so, it’s not a feature in GeneratePress. You would need a custom code or a third party plugin.
I would suggest asking for recommendations on our Facebook Group as well: https://web.facebook.com/groups/generatepress
