Hi there!
I’ve made a sub menu similar to how it’s on generatepress.com, and can’t figure out how to align it horizontally underneath the menu item that opens it.
I’ve added class sub-menu-columns to my main menu item, and use the CSS below to style the sub-menu;
<style> .site-header .main-navigation .sub-menu { border-radius: 10px; box-shadow: none; } /* Styles for sub-menu container */ .sub-menu { width: 500px !important; /* Sets the width of the sub-menu */ padding: 0; /* Removes default padding */ margin: 0; /* Removes default margin */ list-style: none; /* Removes default list styling */ overflow: hidden; /* Ensures content does not overflow and affects the radius */ } /* Styles for sub-menu with columns */ .sub-menu-columns ul.sub-menu li { display: inline-block; /* Aligns list items horizontally */ float: left; /* Floats items to the left */ width: 250px; /* Sets the width of each list item */ border: 1px solid var(--base); /* Adds 1px red border to menu items */ border-right: none; /* Removes right border for items on the left */ border-bottom: none; /* Removes bottom border initially */ box-sizing: border-box; /* Ensures padding and borders are included in the element's width and height */ background-color: white; /* Sets background color of menu items */ border-radius: 0; /* Removes border radius initially */ } /* Add right border back to items on the right (even-numbered) */ .sub-menu-columns ul.sub-menu li:nth-child(even) { border-right: 1px solid var(--base); /* Adds right border to even items */ } /* Add bottom border only to the last two items */ .sub-menu-columns ul.sub-menu li:nth-last-child(-n+2) { border-bottom: 1px solid var(--base); /* Adds bottom border to the last two items */ } /* Border radius for the outermost corners */ .sub-menu-columns ul.sub-menu li:first-child { border-top-left-radius: 5px; /* Top left corner */ } .sub-menu-columns ul.sub-menu li:nth-child(2) { border-top-right-radius: 5px; /* Top right corner */ } .sub-menu-columns ul.sub-menu li:nth-last-child(2) { border-bottom-left-radius: 5px; /* Bottom left corner */ } .sub-menu-columns ul.sub-menu li:last-child { border-bottom-right-radius: 5px; /* Bottom right corner */ } /* Styles for menu item links */ .sub-menu a { font-size: 18px !important; /* Sets the font size of the menu item */ font-weight: bold; /* Makes the menu item text bold */ display: block; /* Ensures the entire link area is clickable */ padding: 25px!important; /* Adds padding for better spacing */ text-decoration: none; /* Removes underline from links */ color: black; /* Sets text color */ transition: background-color 0.3s; /* Smooth transition for background color change */ border-radius: inherit; /* Inherits border-radius from parent li */ } /* Styles for menu item links on hover */ .sub-menu a:hover { background-color: var(--base); /* Changes background color on hover */ } /* Styles for menu item descriptions */ .sub-menu .description { font-size: 13px !important; /* Sets the font size of the description */ display: block; /* Ensures the description is on a new line */ font-weight: normal; /* Keeps the description text regular weight */ margin-top: 5px; /* Adds vertical space between item name and description */ color: black; /* Ensures the description text remains black */ } /* Keep description text color black on link hover */ .sub-menu a:hover .description { color: black; /* Maintains black color for description on link hover */ } </style>
By default it opens the sub menu on click, and aligns the whole sub menu to the left of the menu item that opens it.
I modified it so it opens centered underneath the main menu item that opens it, but it only centers to the left of the main menu item.
Used this modified code:
<style> .site-header .main-navigation { position: relative; /* Ensure the parent is positioned */ } .site-header .main-navigation .sub-menu { border-radius: 10px; box-shadow: none; position: absolute; /* Position relative to parent */ left: 50%; /* Center horizontally */ transform: translateX(-50%); /* Adjust to truly center */ top: 100%; /* Position below the main menu item */ z-index: 1000; /* Ensure it appears above other content */ } .sub-menu { width: 500px !important; /* Set the width of the sub-menu */ padding: 0; /* Remove default padding */ margin: 0; /* Remove default margin */ list-style: none; /* Remove default list styling */ overflow: hidden; /* Ensure content does not overflow */ } .sub-menu-columns ul.sub-menu li { display: inline-block; /* Align items horizontally */ float: left; /* Float items to the left */ width: 250px; /* Set width of each item */ border: 1px solid var(--base); /* Add border to items */ border-right: none; /* Remove right border for items on the left */ border-bottom: none; /* Remove bottom border initially */ box-sizing: border-box; /* Include padding and borders in the element's width and height */ background-color: white; /* Set background color */ border-radius: 0; /* Remove border radius initially */ } .sub-menu-columns ul.sub-menu li:nth-child(even) { border-right: 1px solid var(--base); /* Add right border to even items */ } .sub-menu-columns ul.sub-menu li:nth-last-child(-n+2) { border-bottom: 1px solid var(--base); /* Add bottom border to the last two items */ } .sub-menu-columns ul.sub-menu li:first-child { border-top-left-radius: 5px; /* Top left corner */ } .sub-menu-columns ul.sub-menu li:nth-child(2) { border-top-right-radius: 5px; /* Top right corner */ } .sub-menu-columns ul.sub-menu li:nth-last-child(2) { border-bottom-left-radius: 5px; /* Bottom left corner */ } .sub-menu-columns ul.sub-menu li:last-child { border-bottom-right-radius: 5px; /* Bottom right corner */ } .sub-menu a { font-size: 18px !important; /* Set font size */ font-weight: bold; /* Make text bold */ display: block; /* Ensure the entire link area is clickable */ padding: 25px!important; /* Add padding for spacing */ text-decoration: none; /* Remove underline */ color: black; /* Set text color */ transition: background-color 0.3s; /* Smooth background color transition */ border-radius: inherit; /* Inherit border-radius from parent li */ } .sub-menu a:hover { background-color: var(--base); /* Change background color on hover */ } .sub-menu .description { font-size: 13px !important; /* Set font size for description */ display: block; /* Display description on a new line */ font-weight: normal; /* Normal font weight for description */ margin-top: 5px; /* Space between item name and description */ color: black; /* Ensure description text remains black */ } .sub-menu a:hover .description { color: black; /* Maintain black color for description on hover */ } </style>
I want it centered underneath the main menu item. How can I achieve that?
I can probably just add some margin or padding to get it in the right place, but would like it to be dynamic so it works for different main menu items.
I also tried this solution, but that only aligned the sub menu slightly but not centered completely.
Basically, I miss an option in customizer to change dropdown direction to middle instead of left or right.
I now used this, but I’m hoping for a more elegant solution:
div#primary-menu > ul > li.menu-item-has-children > ul.sub-menu { left: -189px; }
Try this instead:
#primary-menu > ul > li.menu-item-has-children > ul.sub-menu { right: 0; left: 50%; transform: translateX(-50%); }
That worked, thanks!
You’re welcome 🙂
