Nuuji
I would like the elements of two columns to be aligned, even if there’s not the same amount of content for each element. I use flexbox.
I let you see the screenshots to better understand.
Thank you!
You currently created 3 columns (40%,30%,30%), it’s not possible for the 2nd column content to align with the content in 3rd column.
I would suggest creating 2 columns (40%, 60%), and on the right column, use 1st flex container to contain Service clé-en-main and Maintenance préventive de l’équipement, use 2nd flex container to contain Précision exceptionnelle and Surveillance collective.
Here’s a screenshot for your reference: https://app.screencast.com/qXu1s8mVCZzSv
I tested your solution, then I tested with grid, and I have a better result with grid, so I stick with that.
Thank you Ying!
Great! You are welcome 🙂
