psrios
Hi guys, I need your help please, to fix this part of the layout that is broken, as you can see on the image I am pointing it with a red arrow here >> https://ibb.co/Jwp43Dg5 can you please give me some help with it? thanks!
What is the issue? Or how do you want it to be aligned?
psrios
I put the arrow on the image. Can’t you see that the side div where the arrow points to “trending now”should be aligned with the div on the left? There may be some top padding or margin, that I am not being able to find and fix. I tried to fix it and could not find a way, for this reason I am sending this. Thank you for your great willingness to help. By the way, is that only you who works in the support now? Is David there? would be great to hear from him or the other members =)
Have you fixed the issue? This is what I’m seeing now: https://cln.sh/mt39tL0W
psrios
Hi Alvind hope you are great, sorry for the delay, I just saw your message! I have not really fixed the issue properly. I created a class for trendy-now and added -90 top padding value. Do you know a better way? Thank you!
Select the Grid block, and set horizontal alignment to top instead of center.
And set the headline block (Trendy now) to margin-top 0.
psrios
Hi there, thanks for your reply; for some reason, it continues the same
It’s already aligned to the top:
https://app.screencast.com/0bcmVuTlLJmze -
psrios
I cleared the cache and I see it now, thank you Have a great day Ying
No Problem 🙂
