Aligning Buttons on Service 2.0 Starter Site
    Can you please advise on the best way to bottom-align the “Learn More” buttons on the “Primary Service” section of the Service 2.0 starter site once content is added and the columns are varying content lengths? I usually set layout to flex/column, height to 100%, and then button top margin to auto, but that method doesn’t seem to work for this section as it squishes the image at the top of each column.
    Thanks in advance!
    Catherine
    1. Select the parent container of the title Primary service, set flex-grow to 1 in the layout panel > flex layout, set display to flex,flex-direction to column.
    2. Select the Learn more button and set itsmargin-top to auto.
  • catherinetoews
    Perfect! Thanks so much, Ying!
  • You are welcome   🙂
