Alignment out
  • Hi I have setup this deisgn it looks fine in the backend but when at the frontend it is aligned to the left.
    Can I know what am I missing? I have set everything aligned middle.
    Could you please share the page URL where the layout is visible so I can inspect it?
  • there you go
  • The link seems to be invalid — it goes to a Page not found page. Could you verify it?
  • my apologies can u please try again?
  • Select the parent container and, under Layout, set Display to Flex and Flex Direction to Column.
    Next, select both containers inside it and set their left and right margins to auto.
  • Thanks that works?
    Also can I know how to make the
    Mobile background shift to right side on mobile?
    Must I use a different image or it can be achieve by setting?
    No new image is needed. Set the container background Position to right center on the mobile tab. Next, keep Size set to Cover and Repeat to No repeat.
