reora
in this older post, a solution for alternating the columns in rows of a grid is shown:
https://generatepress.com/forums/topic/setting-left-right-layout-for-archives-with-dynamic-elements/however, i’m trying to get this to work in gb2 query/looper/loop item pattern and i can’t get it to work.
should the ‘alternating-layout’ class be added to the query, or looper, or loop-item, or grid, or… ???
thanks!
to the looper.
If it doesn’t work, can you link us to your site?
reora
it’s in looper. url in private info, thank you!
You are using Grid, and the CSS code is for Flex, so no, it won’t work.
Try adding this CSS instead:
.alternating-layout .gb-loop-item:nth-child(2n) > div { grid-auto-flow: row; direction: rtl; } -
reora
you are a star! thank you!!
