Patrick
Hi Support,
When I set a color for active Nav elements, all the Nav elements that are anchor links on the same page show the active css color.
Is there any option to show only the Nav item as active or in that color where the current URL string/param (e.g. #our-team) is the same?
Hi Patrick,
At the moment, GeneratePress doesn’t have a built-in option to handle hash-based active states. To achieve that, you would need to use some custom JavaScript.
Patrick
Hi Alvind,
Thank you for your reply. I think that JS snippet would be a good workaround until perhaps a future fix is released. Could you please share the JS?
Appreciate your support!
Thank you
Are you using the default GP site header/navigation or a custom site header?
Can you link me to your site?
