Angled label at top right corner of container
  • Hi there!
    I want to add a label to the corner of a container like this:
    https://jmp.sh/KtFmZSXU
    I’ve now done it by adding a headline block into a container, and then adding a bunch of negative padding like this:
    https://jmp.sh/NWfH3MsA
    Then, of the parent container (white block) I set oveflow-y to hidden.
    This is working and gives the result above, but it’s not a very neat solution.
    Isn’t there an easier way to add such a label? I especially don’t like to have to guess the bottom margin so that the content underneath appears to be normal. I basically want the label to not take up space, and just the be there.
    Hope that’s clear. Thanks! 😄
    it’s a tricky design element to get right as theres a lot of variables to consider, from the length of the text, the topography settings, spacing where it has to sit in the container ….
    So I don’t have a one size fits all solution but if you want me to take a look at what you have done so far I would be happy to.
  • Thanks! I’ve played around a bit more with it and now did it directly to the headline block, seems to work well and is a bit simpler: https://jmp.sh/lajFjJci
  • Looks good 🙂
